2011 LS460 Clock
2011 LS460 Clock
When I got my car back from the dealer after installing a new dash (warranty), the clock was way off and I couldn't adjust it thru normal settings. When I took it back in, the svc. rep. went into clock setting and changed it from auto to manual and input the proper time. Then he put it back on auto and that fixed the problem. The reason I mention this is that the clock problem threads I had read here said if you couldn't change the clock setting, then the clock was toast.
