2007 LS460- P0010 camshaft position actuator circuit/open
I just got this code with CEL and VSC lights all on. Car still drives fine. What part should I be looking at for this code? I have an 2007 LS460
The VVTi-E or VVT control motors should be inspected and the harness checked for continuity, look up the motor specs to test them.
I am not sure based on your discripton what exactly is having an issue since you have two types of cam control systems and you didn't specify intake or exhaust
I have a 2007 LS460 I can't part with. I am getting a P0020 Cam Shaft actuator open circuit warning. I pulled both units (left and right bank) and I switched them. I cleared the error and it returned immediately and IDENTICAL!. I switched banks so the error should have switched banks right? So I believe the issue is the left bank wiring between the solenoid and wherever the wires go to. I can't see where the wiring terminates though. I would like to disconnect and bypass the wiring to test. Any thoughts?
Yes, but I don't discount the wiring along the path to the ECU or the connector at the ecu. Problem is that the wiring disappears in the loom and I do not know where the ECU is located to check the other end. If you can direct me or post a photo where the wiring terminate from the bank 2 actuator that would be helpful. TY
