Engine misfire
Engine misfire
Hi all I recently posted about p0171 error on Lexus LS 460 2008. I went to a mechanic and did a guess work by changing all the spark plugs. Now the car is even running worse then before. I suspect there are multiple misfires
can you guys tell me any good mechanic in Dubai or sharjah uae or what are right spark plugs for it.
Clear the code and see if the same codes pop up again or the code changes
2nd i wanted to ask you did the misfire started after the oil leak repair or was it from the start ?
3rd american spec sparks or gcc wont make your car misfire i usually replace the sparks with the american specs .
4th. Did you check for any vaccum leaks ?
my few suggestions
Misfire started after fixing the gas kit. Tho it is leaking even more now also from the oil line which connects on the top
I have asked many mechanics to do the vacuum test and they keep bull****ing with other stuff. Either they don't know how to do it or either they just want to make some money. So no vacuum test.
If you can share some info on how to do it might I might check it myself
And before changing the spark plugs there was no misfire. I mean not really a no but like 1 once in a day and car will run smooth on the high ways
You need to provide pictures of leaks. There is no actual oil line anywhere on top. However, there are ventilation lines coming off engine covers.
If your mechanic is incompetent, there is no point to ask him to fix anything.
I agree with him if your mechanic is useless better to take your car to some other garage. My friends with ls430 go to some guy in ajman and they swear that hes the best till now i havent visited him with the 460 you can atleast visit him and have a look at your car
Abbasahmd1 (06-21-21)
Hi I did run the scanner on it time to time p0171 is there always just cylinder misfire code changes to different cylinders. And some times o2 sensors
I think you have obd2 reader did you see your sthort term fuel trim ? What are the readings if they are negative it means there is a leak somewhere
Or you can try to use the soapy water near the intake lines to see if there is a leak your mechanic should atleast know how to look and listen for leaks
I been to many now and I can't seem to find a good one who understands the work all they do is labor job if you know any do share the contact
Great please let me know the guy I will surely visit him
Did you clear the codes time to time ?
I don't have the OBD2 reader but now am thinking to buy one fuel trim levels I have checked long back it is running like this for almost 6months and I have wasted alot of $$ on it also if you can share the somekind of diagram for vacuum lines I can look them up. I really want to fix it as the renewal is coming next week and I have to take the car for passing.
If I had to guess, I'd say you have at least one if not more bad ignition coils. I say more than one because after changing the plugs it got worse, so probably another coil was damaged.
You might find this site helpful -
https://www.motorbiscuit.com/is-it-y...oil-thats-bad/
Bro you need to be sure if this is happening from past 6months or after the last oil leak wprk that you did .. i will send you the number in messages
