Does the 2007 LS460 have two bulbs per side for the rear turn signals?
Just ordered some LEDs with built-in resistors for the rear turn signals, but it appears that the turn signals require two bulbs on each side on the 2007 model?
Parts listing shows 2 per side
https://www.japan-parts.eu/lexus/us/...mbination-lamp
Get an LED compatible flasher instead, verify but I think the CF18 will work in your car. I will warn you, every one of these I've tried the 1st flash is longer than the rest I find this very annoying. Other people don't mind it.
.....are some of these tail lamps integrated LEDs meaning can't replace anything?
Yes 4 bulbs total. Which bulbs are you looking to get? Stock bulb is about 4 watts each so a 25-30 ohm resistor per side would be about right. The flasher might use the front bulbs as the load sense so it won't matter what you put in the rear, test this by removing 1 or both bulbs see if you get hyperflash.
