Drive Belt
jud149 (07-12-21)
drive belts can last a long time, it is good practice to keep maintained, I use 303 rubber protectant. It's not an expensive maintenance item, if you do it yourself it's like $30 and 10 minutes. I would say probably in the 60k mile range in general.
jud149 (07-12-21)
I have literally seen drive belts last past 100,000 miles. When I changed mine on my LS460 I believe it was around 100,000 miles - I was waiting for the water pump to fail first, which it never did, so I ended up buying a belt with a lifetime warranty for a little bit more (which I never got use because I traded the car in at 178,000 miles). And that original water pump was still going strong.
But, a belt can fail very quickly if there is anything wrong with any of the pulleys, idler pulleys, tensioner.
jud149 (07-13-21)
I recently had my 96K-kms service (actually @99K kms) and under 'recommended/deferred services', tech's note shows "replace serpentine belt ... squeaking". I think it's faint squeaking as I can't really hear it pronounced.
Anyways ... the vehicle will be @ ~107K-kms so will have it included on the next service interval, costs C$219.95 +ss +tax
jud149 (07-20-21)
I replaced the serpentine belt on my 2012 at 85,000 miles, and was shocked to see that the original belt was in near-perfect condition. The idler pulleys were noiseless and smooth when spun. Yet another example of the extreme quality - both of design and manufacturing - you get with this car.
jud149 (07-24-21)
jud149 (07-27-21)
peterls
10-23-19 02:20 PM
