Big three engine to chassis ground?
The engine has multiple ground wires connecting it to the chassis. If you need an engine-to-chassis wire or mount point, you can use any nut or bolt used to attach things to chassis. It is recommended to test ground connection after it was setup.
Mewannalex
11-12-19 02:02 PM
