Need help urgently. ABS issue 😭
Good day guys,
My car have this problem regarding to ABS. Went to mechanic to scan and have changed 3 different parts regarding to ABS pump. But still, problem exists and engine check light keep appearing after resetting, about 7 days after every reset.
I would really appreciate if someone could help. I think this is a very common issues, anyone encountered the same problems?
Which 3 parts were replaced? Do you have the part numbers?
Have you extracted the error codes before replacing anything?
If i am not wrong usually check vsc is also poped up if the code ia reffering to actuator .. if you can provide the codes that were pulled up would be great help .. i had similar error but it was the brake sensor located behind the brake pedal but it all depends on codes
RefinedGS
Suspension and Brakes
02-25-04 02:39 PM
