Those with roof mounted rear tv - how to remove trim?
Hi anyone of you have the repair manual or step by step guide ? I need to know how to remove the wood trim on the roof . This is probably different from other models as it seems to be secured by a whole bunch of screws from the back, which means I need to lower the whole thing that holds the screen probably…
Anyone ?? Thanks in adv
Unfortunately I don't have anything helpful for you. But I was wondering if you removed the upper B pillar trim? Mine feels like it is going to snap as I pull on it. My passenger side needs to be recovered as it's quite worn.
You are talking about near the windshield I read something about it, one of the tabs cannot be reused and needs to be cut out don’t quote me a google should give you a how to
This is the only step that is added for models with rear tv.
jdanielca (08-20-21)
The one near the windshield is called A pillar. The b pillar is between the front and rear doors. I've heard they often crack on removal. I probably just need to pull harder :/
ALK (08-20-21)
miket000 (08-21-21)
