Windshield wiper fluid stopped
Ran out of fluid, couple of days later i refilled it then nothing sprays hahaa the headlamps are still getting it though. Clogged? This morning i forgot and smeared everything... i pulled right over used microfiber towel to clean it. Any quick fix ideas?
thanks guys
thanks guys
I would disconnect a hose to one of the nozzles and check if the fluid comes out when try to use the windshield washer.
Boomin (08-26-21)
I would assume the windshield water pump is dead . They die randomly. I changed mine last year . Only remove the left wheel well cover then replace it . Also the headlamp cleaner is ran using a separate pump .
Windshield pump # 85330-60190
Boomin (08-26-21)
Keep pumping it, maybe it just takes a while to prime the whole system.
Excellent, thanks guys!
