Hey all
I found couple of 07 LS460 in CA and NC and both have around 120k on odo.
They have some dealer records but both require 120k service. They would also need control arms (never done) and possibly brake actuator -- no brake lights but still looking at the failures.
They both have ML, Park assist and Nav but the one in NC also have Radar cruise and leather semi aniline leather door panel in SWB (please see pic). I have maintained my LS400 for the past 35k miles - I have done the dreaded starter, all fluids and random work but never suspension or ABS modules. So what y all think. It never hurts to write them a number. Buying a car in the pandemic is nothing but pain so far.
The NC vehicle is a pretty rare bird, having the Comfort Plus option in a short wheelbase. Hopefully, the filthy seat belt is not indicative of its overall condition. As has been discussed in other recent threads, price is so very dependent on ownership, service, and accident history.
Can you afford a newer car with less miles? If so, get a newer car.
I can spend as much as 20k but I am not seeing anything with decent miles hitting the market in the tan interior I want. And also all those hitting at 100k miles in 2012 also requires suspension work or bunch of other maintenance items.
I plan to keep the LS460 maybe for three years or so before I get another (?)
perhaps. No accidents and bunch of oil changes and brake adjustments at the dealership. I see the dealer saying alignment issues and uneven tire wear on inside on NC car - so I translate that as it requires suspension work.
the NC car also has leather on door panels on SWB and radar cruise which I havent seen in SWB LS.
I thought about running quote on carmax for the VIN and offering maybe +2k over the number. But I see its like $7k-$8k on carmax or caravan for these cars.
I would avoid cars with a lot of luxury items. I talked a guy, I know, from Lexus couple days ago. He said that they had traded in LS600 with a driver monitoring camera which failed. It costs over 2k+ just the part, they are going to action the car because it is not worth to repair. That is a good example why some luxuries features could be not so useful but very expensive to repair.
So anybody know if Radar in LS460 is damaged still it's drivable? I think so.
600h is very rare bird.
Took a quick look at CarMax, and see in Palmdale a 2010 with 88k miles for $20k. But, not a tan interior.
I have radar cruise control on my car. It has never failed so I'm not positive but I'm sure the car would be drivable. In fact, I would bet that the normal cruise control would still be operable even if the radar failed.
Sure it would be drivable. Radar cruise in a very heavy rain stops working (as designed when it can't "see sufficiently") and the car still works and drives just fine, just without cruise control.
I also suspect there is a way to also just turn off radar cruise and have cruise work as a standard cruise control - there was on the 3LS, I've never looked for it on the 4LS but bet it's there.
To active the normal cruise , just turn on the cruise control stalk then the push the stalk away from you for a few second , then normal cruise is enabled .
SERVICE: 110K MILE SVC
DESCRIPTION: 110K MILE SVC ~|~CUSTOMER REQUESTS A 110K MILE SERVICE ~|~CUSTOMER REQUESTS A 110K MILE SERVICE ~|~PERFORMED A 110K MILE SERVICE PER CUSTOMER'S REQUEST TOPPED OFF WASHER FLUID RESERVOIR. TORQUED WHEELS 103FT LBS. BRAKE PAD THICKNESS FRONTS… READ MORE
SERVICE: 120K MILE SVC
DESCRIPTION: 120K MILE SVC ~|~ ~|~,CUSTOMER DECLINED SERVICE
SERVICE: 4 WHEEL ALIGNMENT
DESCRIPTION: 4 WHEEL ALIGNMENT ~|~ ~|~,CUSTOMER DECLINED SERVICE
SERVICE: AIRFILTER REPLACEMNT
DESCRIPTION: AIRFILTER REPLACEMNT ~|~REPLACE ENGINE AIR FILTERS PER RECOMMENDATIONS DIRTY ENGINE FILTERS. ~|~ ~|~REPLACED ENGINE AIR FILTERS
SERVICE: CAR WASH
DESCRIPTION: CAR WASH ~|~CUSTOMER STATES PERFORM COMPLIMENTARY CAR WASH WE ARE NOT RESPONSIBLE FOR WINDSHIELD THERMAL BREAKAGE DURING THE WASH ~|~ ~|~PERFORMED CAR WASH
SERVICE: CHECK BATTERY CHARGE
DESCRIPTION: CHECK BATTERY CHARGE ~|~GENERAL BATTERY HEALTH CHECK PER CLIENT REQUEST ~|~ ~|~TESTED BATTERY. BATTERY STATE OF HEALTH GOOD. RATED COLD CRANKING AMPS:725. MEASURED:690
SERVICE: CHECK FLOOR MAT INST
DESCRIPTION: CHECK FLOOR MAT INST ~|~CUSTOMER STATES VERIFY THE DRIVERS FLOOR MAT IS CORRECT FOR THE VEHICLE AND THE FASTENERS ARE SECURED ~|~ ~|~REMOVED STACKED NON SECURED AFTER MARKET FLOOR MAT FROM DRIVERS SIDE & PLACED IN CARGO AREA/TRUNK FOR YOUR… READ MORE
SERVICE: FT. SUSP. CONCERN
DESCRIPTION: FT. SUSP. CONCERN ~|~ ~|~,CUSTOMER DECLINED SERVICE
SERVICE: GENERAL REPAIR
DESCRIPTION: GENERAL REPAIR ~|~WHEEL LOCK KEY SET- WHEEL LOCK KEY MISSING.LEFT REAR LOCK BROKEN & DIFFICULT TO REMOVE. ~|~ ~|~INSTALLED NEW WHEEL LOCK KEY SET. TORQUED TO 103FT LBS. NEW WHEEL LOCK KEY PLACED IN GLOVE BOX
SERVICE: NON WARRANTABLE OPERATION CODE
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~PLEASE PERFORM INVITATION ONLY COMPLIMENTARY VEHICLE INSPECTION-SEE ATTACHED SHEET ~|~ ~|~PERFORMED INVITATION INSPECTION. SEE REPORT CARD FOR DETAILS.------SECURED LOOSE AFTERMARKET BATTERY FOR YOUR SAFET… READ MORE
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~ ~|~,CUSTOMER DECLINED SERVICE
SERVICE: TIRE PRESS INSPECT
DESCRIPTION: TIRE PRESS INSPECT ~|~CHECK/ADJUST TIRE PRESSURES AND REPORT FINDINGS ~|~ ~|~TIRE PRESSURE AT 33PSI
SERVICE: TRANSFORM DISINFCTNT
DESCRIPTION: TRANSFORM DISINFCTNT ~|~GUEST REQUESTS TO HAVE VEHICLE INTERIOR SANITIZED WITH METROTECH TRANSFORM DISINFECTANT SOLUTION. ~|~ ~|~APPLIED TRANSFORM DISINFECTANT TO INTERIOR OF VEHICLE
SERVICE: VALVOLINE BRAKE FLUI
DESCRIPTION: VALVOLINE BRAKE FLUI ~|~CUSTOMER STATES PERFORM VALVOLINE BRAKE FLUID EXCHANGE 0.8- DISCOLORED; NO 90K SERVICE HISTORY. ~|~MAINTENANCE ~|~PERFORMED BRAKE FLUID EXCHANGE SERVICE
SERVICE: VEHICLE PICK UP
DESCRIPTION: VEHICLE PICK UP ~|~COMPLIMENTARY VEHICLE PICK UP AND DELIVERY. ~|
SERVICE: WIPER REFILLS
DESCRIPTION: WIPER REFILLS ~|~CUSTOMER REQUESTS REPLACE FRONT WIPER REFILLS INSERTS TORN & HEAVY STREAKING. ~|~CUSTOMER REQUESTS REPLACE FRONT WIPER REFILLS ~|~REPLACED FRONT WIPER INSERTS. TOPPED OFF WASHER FLUID RESERVOIR
110000 MILES
DATE 07/2020
SERVICE: CAR WASH
DESCRIPTION: CHECK FLOOR MAT INST ~|~CUSTOMER STATES VERIFY THE DRIVERS FLOOR MAT IS CORRECT FOR THE VEHICLE AND THE FASTENERS ARE SECURED ~|~ ~|~DRIVERS FLOOR MAT IS CORRECTLY INSTALLED FOR THE VEHICLE AND THE FASTENERS ARE SECURED
SERVICE: MAINT.
DESCRIPTION: MAINT. ~|~CLIENT REQUESTS TO HAVE THE OIL CHANGE SERVICE PERFORMED ~|~ ~|~COMPLETED OIL CHANGE SERVICE AS REQUESTED
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~PLEASE PERFORM INVITATION ONLY COMPLIMENTARY VEHICLE INSPECTION-SEE ATTACHED SHEET ~|~ ~|~COMPLETED COMPLIMENTARY VEHICLE INSPECTIONS. DURING BRAKE INSPECTION; FOUND L/R WHEEL LOCK DAMAGED, BUT CAN STILL B… READ MORE
DESCRIPTION: TIRE PRESS INSPECT ~|~CHECK/ADJUST TIRE PRESSURES AND REPORT FINDINGS ~|~ ~|~TIRE PRESSURES ARE SET TO 33 PSI
103806 MILES
DATE 03/2020
SERVICE: AUTO TRANS CONCERN
DESCRIPTION: AUTO TRANS CONCERN ~|~CLIENT STATES ON 3/9/2020, I LEFT FROM WORK AND I TOOK THE HIGHWAY 880N AND JUST AS I MERGED INTO TRAFFIC AND STARTED ACCELERATING, MY CAR'S TRANSMISSION DID NOT SHIFT FOR A BRIEF MOMENT. AFTER DRIVING ON CITY STREETS… READ MORE
SERVICE: BRAKE SHIMMY
DESCRIPTION: BRAKE SHIMMY ~|~DURING THE ROAD TEST TECH 203 AND CLIENT FELT SHIMMY IN VEHICLE WHEN BRAKING AT FREEWAY SPEEDS PLEASE INSPECT BRAKES AND ADVISE. ~|~ ~|~DURING ROAD TEST CONFIRMED CUSTOMERS COMPLAIN OF BRAKE VIBRATION AT HIGH SPEED. INSPECT… READ MORE
SERVICE: CAR WASH
DESCRIPTION: CHECK FLOOR MAT INST ~|~CUSTOMER STATES VERIFY THE DRIVERS FLOOR MAT IS CORRECT FOR THE VEHICLE AND THE FASTENERS ARE SECURED ~|~ ~|~FLOOR MAT SECURE
SERVICE: DETAIL
DESCRIPTION: DETAIL ~|~CLIENT REQUESTS INTERIOR PERFORMING INTERIOR DETAIL AT THIS TIME. FOCUSING ON THE CARPET ESPECIALLY THE DRIVERS SIDE FRONT SEAT AREA. ~|~ ~|~PERFORMED INTERIOR DETAIL
SERVICE: DIFFERENTIAL OIL
DESCRIPTION: DIFFERENTIAL OIL ~|~CUSTOMER AUTHORIZED VALVOLINE REAR DIFFERENTIAL OIL SERVICE ~|~ ~|~PERFORMED REAR DIFF SERVICE AS REQUESTED. RELACED FILL AND REFILL DRAIN PLUG GASKETS
SERVICE: ENTERPRISE RENTAL
DESCRIPTION: ENTERPRISE RENTAL ~|~PROVIDE 24 HOURS OF ENTERPRISE CAR RENTAL WHILE GUESTS VEHICLE IS SERVICED. - GUEST IS RESPONSIBLE FOR ADDITIONAL DAY, FUEL, INSURANCE OR UPGRADES ~|
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~PLEASE PERFORM INVITATION ONLY COMPLIMENTARY VEHICLE INSPECTION-SEE ATTACHED SHEET ~|~ ~|~PERFORMED MPI
DESCRIPTION: TIRE PRESS INSPECT ~|~CHECK/ADJUST TIRE PRESSURES AND REPORT FINDINGS ~|~ ~|~TIRE PRESSURE SET TO SPECS
SERVICE: TRANS SERVICE MINOR
DESCRIPTION: TRANS SERVICE MINOR ~|~GUEST REQUEST MINOR TRANSMISSION SERVICE. LT 0.8 ~|~ ~|~DRAIN AND FILL TRANSMISSION FLUID. REPLACE DRAIN PLUG GASKET
98463 MILES
DATE 12/2018
SERVICE:
DESCRIPTION: LEXUS LOANER PROVIDED FOR DURATION OF SERVICE. REQUIREMENTS FOR LOANER INCLUDE VALID DRIVERS LICEN
SERVICE:
DESCRIPTION: LEXUS LOANER PROVIDED FOR DURATION OF SERVICE. REQUIREMENTS FOR LOANER INCLUDE VALID DRIVERS LICEN ~|~LEXUS LOANER PROVIDED FOR DURATION OF SERVICE. REQUIREMENTS FOR LOANER INCLUDE VALID DRIVERS LICENSE, CREDIT CARD AND CURRENT PROOF OF IN… READ MORE
SERVICE:
DESCRIPTION: YOU CONSENT TO RECEIVING TEXTS FROM US ON YOUR CELL PHONE. YOU AGREE THAT WE MAY CONTACT YOU REGAR
SERVICE:
DESCRIPTION: YOU CONSENT TO RECEIVING TEXTS FROM US ON YOUR CELL PHONE. YOU AGREE THAT WE MAY CONTACT YOU REGAR ~|~YOU CONSENT TO RECEIVING TEXTS FROM US ON YOUR CELL PHONE. YOU AGREE THAT WE MAY CONTACT YOU REGARDING SERVICE UPDATES OR OFFERS VIA TEXT… READ MORE
SERVICE:
DESCRIPTION: INCLUDED MULTI-POINT INSPECTION- BRAKE PAD / TIRE TREAD DEPTH MEASUREMENTS, BATTERY VISUAL / STORA
SERVICE:
DESCRIPTION: INCLUDED MULTI-POINT INSPECTION- BRAKE PAD / TIRE TREAD DEPTH MEASUREMENTS, BATTERY VISUAL / STORA ~|~INCLUDED MULTI-POINT INSPECTION- BRAKE PAD / TIRE TREAD DEPTH MEASUREMENTS, BATTERY VISUAL / STORAGE CAPACITY TEST, INTERIOR / EXTERIOR L… READ MORE
SERVICE: CHECK DRIVERS FLOOR MAT FOR PROPER INSTALLATION
DESCRIPTION: CHECK DRIVERS FLOOR MAT FOR PROPER INSTALLATION ~|~CHECK DRIVERS FLOOR MAT FOR PROPER INSTALLATION ~|~ ~|~98463 10 REMOVED ONE FLOOR MAT FROM DRIVERS SIDE AND PLACED ON TOP OF THE PASSENGER FRONT MAT. SECURED ONE FLOOR MAT TO CARPET ANCHOR… READ MORE
SERVICE: DEALER RECOMMENDED OPERATION-ADD WINDSHIELD WASHER FLUID
DESCRIPTION:
SERVICE: DEALER RECOMMENDED OPERATION-FUEL INJECTION ADDITIVE
DESCRIPTION:
SERVICE: DEALER RECOMMENDED OPERATION-INSTALL BATTERY TERMINAL PROTECTORS
DESCRIPTION:
SERVICE: DEALER RECOMMENDED OPERATION-REPLACE ENGINE OIL - SYNTHETIC
DESCRIPTION:
SERVICE: DEALER RECOMMENDED OPERATION-REPLACE REMOTE KEY BATTERY
DESCRIPTION:
SERVICE: FOUR WHEEL COMPUTER ALIGNMENT- SPECIAL
DESCRIPTION: FOUR WHEEL COMPUTER ALIGNMENT- SPECIAL ~|~ ~|~,CUSTOMER DECLINED SERVICE
SERVICE: GUEST HAS SOME CLIPS MISSING UNDER THE HOOD PLEASE PLACE NEW CLIPS IN VEHICLE
DESCRIPTION: GUEST HAS SOME CLIPS MISSING UNDER THE HOOD PLEASE PLACE NEW CLIPS IN VEHICLE ~|~GUEST HAS SOME CLIPS MISSING UNDER THE HOOD PLEASE PLACE NEW CLIPS IN VEHICLE ~|~MISSING CLIPS ~|~98463 MISSING CLIPS REPLACED CLIPS
SERVICE: GUEST RECEIVED A LETTER FOR ZLZ CAMPAIGN PLEASE CHECK AND SEE IF GUEST QUALIFY
DESCRIPTION: GUEST RECEIVED A LETTER FOR ZLZ CAMPAIGN PLEASE CHECK AND SEE IF GUEST QUALIFY ~|~GUEST RECEIVED A LETTER FOR ZLZ CAMPAIGN PLEASE CHECK AND SEE IF GUEST QUALIFY ~|~ZLZ INSPECTION ~|~98463 ZLZ INSPECTION INSPECTED DASH PAD. DASH PAD DOES NO… READ MORE
SERVICE: INSPECT ALL LIGHTS AND REPORT
DESCRIPTION:
SERVICE: INSPECT BRAKE PADS AND/OR LININGS, ROTORS AND/OR DRUMS
DESCRIPTION:
SERVICE: PERFORM BATTERY TEST AND REPORT
DESCRIPTION:
SERVICE: REPLACE 4 TIRES
DESCRIPTION: REPLACE 4 TIRES ~|~ ~|~,CUSTOMER DECLINED SERVICE
SERVICE: REPLACE CABIN AIR FILTER
DESCRIPTION:
SERVICE: REPLACE ENGINE COOLANT
DESCRIPTION:
SERVICE: REPLACE ENGINE OIL
DESCRIPTION:
SERVICE: REPLACE ENGINE OIL FILTER
DESCRIPTION:
SERVICE: RESET SERVICE INDICATOR
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
SERVICE: ROTATE TIRES
DESCRIPTION:
SERVICE: SERVICE - 100,000 MILES
DESCRIPTION: SERVICE - 100,000 MILES ~|~SERVICE - 100,000 MILES ~|~MAINTENANCE ~|~98463 MAINTENANCE 330 COMPLETED 100K PER LIST. TIRES 4/32. ALL TIRE ARE WEARING MORE ON INSIDE EDGES. CURRENT TIRES ARE MICHELIN ENERGY A/S P235/50R18. TIRES ARE FROM 201… READ MORE
SERVICE: SET TIRE PRESSURE TO MANUFACTURER SPECS.
DESCRIPTION: SET TIRE PRESSURE TO MANUFACTURER SPECS. ~|~SET TIRE PRESSURE TO MANUFACTURER SPECS. ~|~TIRE PRESSURE INSPECTION ~|~98461 TIRE PRESSURE INSPECTION ADJUSTED TIRE PRESSURES TO R/F 33 PSI L/F 33 PSI R/R 33 PSI L/R 33 PSI
SERVICE: SUPPORTS, HOOD - REPLACE
DESCRIPTION: SUPPORTS, HOOD - REPLACE ~|~ ~|~,CUSTOMER DECLINED SERVICE
95222 MILES
DATE 04/2018
SERVICE:
DESCRIPTION: GUEST STATES: ROUTINE MAINTENANCE// BATTERY WAS REPLACED AND LIGHTS ARE NOW BLINKING
SERVICE:
DESCRIPTION: GUEST STATES: ROUTINE MAINTENANCE// BATTERY WAS REPLACED AND LIGHTS ARE NOW BLINKING ~|~GUEST STATES: ROUTINE MAINTENANCE// BATTERY WAS REPLACED AND LIGHTS ARE NOW BLINKING ~|
DESCRIPTION: CHECK DRIVERS FLOOR MAT FOR PROPER INSTALLATION ~|~CHECK DRIVERS FLOOR MAT FOR PROPER INSTALLATION ~|~FLOORMAT ~|~95222 FLOORMAT INSPECTED FLOOR MAT AND VERIFY PROPER INSTALLATION AT THIS TIME
SERVICE: GUEST DECLINED VISUAL VEHICLE INSPECTION
DESCRIPTION: GUEST DECLINED VISUAL VEHICLE INSPECTION ~|~GUEST DECLINED VISUAL VEHICLE INSPECTION ~|
SERVICE: OTHER INSPECTION
DESCRIPTION: OTHER INSPECTION ~|~GUEST STATES THAT AFTER BATTERY WAS REPLACED 2 WEEKS AGO, THE NAV SYSTEM WILL BOOT UP AND THEN WILL REBOOT. RADIO WILL ALSO TURN OFF. CHECK AND ADVISE. ~|~NAV RESET ~|~95222 NAV RESET CONFIRMED GUEST CONCERN, PERFORMED… READ MORE
DESCRIPTION: SET TIRE PRESSURE TO MANUFACTURER SPECS. ~|~SET TIRE PRESSURE TO MANUFACTURER SPECS. ~|~TIRE PRESSURE ~|~95222 TIRE PRESSURE ADJUSTED TIRE PRESSURES TO R/F33 L/F33 R/R33 L/R33
76421 MILES
DATE 08/2015
SERVICE:
DESCRIPTION: COMPLIMENTARY SAFETY INSPECTION.CHECK FOR POSSIBLE TRANSMISSION PAN GASKET LEAKING AND ADVISE.CHEC
SERVICE:
DESCRIPTION: COMPLIMENTARY SAFETY INSPECTION.CHECK FOR POSSIBLE TRANSMISSION PAN GASKET LEAKING AND ADVISE.CHEC ~|~COMPLIMENTARY SAFETY INSPECTION.CHECK FOR POSSIBLE TRANSMISSION PAN GASKET LEAKING AND ADVISE.CHECK FOR UPPER CONTROL ARM BUSHINGS - TORN… READ MORE
DESCRIPTION: CHECK DRIVERS FLOOR MAT FOR PROPER INSTALLATION ~|~CHECK DRIVERS FLOOR MAT FOR PROPER INSTALLATION ~|~ ~|~76421 AS PART OF OUR AND LEXUS ONGOING COMMITMENT TO GUEST SAFETY, WE HAVE REMOVED EITHER AN UNSECURED OR IMPROPER FLOOR MAT AND PLAC… READ MORE
SERVICE: ELF-REPL FUEL PRESSURE GASKE T-IS F,GS460,LS460,LS600H
DESCRIPTION: ELF-REPL FUEL PRESSURE GASKE T-IS F,GS460,LS460,LS600H ~|~SAFETY RECALL ELF - REMEDY NOTICE - VARIOUS MODELS - POTENTIAL FUEL PRESSURE SENSOR LEAK ~|~. ~|~76421 REPLACED FUEL PRESSURE SENSOR GASKET AS PER ELF SAFETY RECALL INSTRUCTIONS. FI… READ MORE
SERVICE: GASKET, PAN - AUTOMATIC TRANSMISSION - REPLACE
DESCRIPTION: GASKET, PAN - AUTOMATIC TRANSMISSION - REPLACE ~|~ ~|~,CUSTOMER DECLINED SERVICE -CUSTOMER DECLINED
DESCRIPTION: SET TIRE PRESSURE TO MANUFACTURER SPECS. ~|~SET TIRE PRESSURE TO MANUFACTURER SPECS. ~|~ ~|~76421 ADJUSTED TIRE PRESSURES TO R/F33 L/F33 R/R33 L/R33
43854 MILES
DATE 12/2010
SERVICE: CHECK P.S.I AND ADJUST TIRE PRESSURE AS NEEDED
DESCRIPTION: CHECK P.S.I AND ADJUST TIRE PRESSURE AS NEEDED ~|~GUEST STATES: CHECK TIRE PRESSURE BEFORE R/F 33 L/F33 R/R33 L/R 33 AFTER R/F 33 L/F33 R/R33 L/R33 ~|~PSI ~|~CHECK P.S.I AND ADJUST TIRE PRESSURE AS NEEDED ADJUSTED ALL TIRES TO 33PSI
SERVICE: INSTALL NEWLY DESIGNED VALVE SPRINGS
DESCRIPTION: INSTALL NEWLY DESIGNED VALVE SPRINGS ~|~GUEST STATES: ALE CAMPAIGN ~|~VALVE SPRING HAS POTENTIAL TO BREAK CAUSING ROUGH IDLE AND OR ENGINE NOISE ~|~INSTALL NEWLY DESIGNED VALVE SPRINGS INSTALLED NEWLY DESIGNED VALVE SPRINGS
38776 MILES
DATE 01/2010
SERVICE: BALANCED 4 TIRES
DESCRIPTION: BALANCED 4 TIRES ~|~BALANCE 4 TIRES ~|~ ~|~BALANCED 4 TIRES
SERVICE: CHECKLIST COMPLETED AS REQUIRED. MILES OUT:38776
DESCRIPTION: CHECKLIST COMPLETED AS REQUIRED. MILES OUT:38776 ~|~LEXUS OF ORLANDO ELITE MULTI-POINT INSPECTION. PROMISE TIME IS: NOTE TO TECHNICIAN - PLEASE DOCUMENT MILES OUT ON COMPLETION. ~|~ROADTESTED. ~|~CHECKLIST COMPLETED AS REQUIRED. MILES OUT… READ MORE
SERVICE: COURTESY VEHICLE - LEXUS LOANER TO GUEST
DESCRIPTION: COURTESY VEHICLE - LEXUS LOANER TO GUEST ~|~PROVIDE GUEST WITH COMPLIMENTARY LEXUS LOANER ~|~ ~|~COURTESY VEHICLE - LEXUS LOANER TO GUEST
SERVICE: OK.
DESCRIPTION: OK. ~|~INSPECT VEHICLE FOR IMPROPERLY INSTALLED L/F FLOOR MAT, STACKED MATS, INCORRECT MAT, MISSING RETAINING CLIPS AS PER LEXUS CONSUMER SAFETY ADVISORY ~|~OK. ~|~OK
SERVICE: PERFORM 35,000 MILE SERVICE.BRAKES:4MM & 3MM FROM SENSOR.TIRES:5/32,6/32NDS.
DESCRIPTION: PERFORM 35,000 MILE SERVICE.BRAKES:4MM & 3MM FROM SENSOR.TIRES:5/32,6/32NDS. ~|~PERFORM 35,000 MILE SERVICE ~|~ ~|~PERFORM 35,000 MILE SERVICE.BRAKES:4MM & 3MM FROM SENSOR.TIRES:5/32,6/32NDS
SERVICE: PERFORM PRESIDENTIAL DETAIL
DESCRIPTION: PERFORM PRESIDENTIAL DETAIL ~|~PERFORM PRESIDENTIAL DETAIL ~|~ ~|~PERFORM PRESIDENTIAL DETAIL
SERVICE: PERFORMED COMPLIMENTARY WASH AND VACUUM
DESCRIPTION: PERFORMED COMPLIMENTARY WASH AND VACUUM ~|~PERFORM WASH & VACUUM AFTER SERVICE ~|~ ~|~PERFORMED COMPLIMENTARY WASH AND VACUUM
SERVICE: REPOSITIONED SERVO LEVER IN PLACE.NOW WORKING AS DESIGNED.
DESCRIPTION: REPOSITIONED SERVO LEVER IN PLACE.NOW WORKING AS DESIGNED. ~|~C/S THERE IS A LOUD THUMPING NOISE COMING FROM BEHIND THE GLOVE BOX. KARL G. C/S WHEN TRYING TO PUT AIR CONDITION ON IN VEHICLE, NONE OF THE FUNCTIONS WORK. CHECK AND ADVISE. ~|… READ MORE
33795 MILES
DATE 09/2009
SERVICE: CUSTOMER STATES
DESCRIPTION: CUSTOMER STATES ~|~CUST STATES LOW KEY BATTERY. ~|~ ~|~INSTALLED NEW KEY BATTERY
SERVICE: FRONT/REAR BODY
DESCRIPTION: FRONT/REAR BODY ~|~CUST STATES ENGINE COVERS UNDER HOOD AND UNDER CAR MISSING CLIPS. ~|~ ~|~REPLACED MISSING CLIPS,REINSTALLE LOWER COVER
SERVICE: FUEL RAIL
DESCRIPTION: FUEL RAIL ~|~SSC 9LA FUEL RAIL REPLACEMENT ~|~SSC 9LA ~|~COMPLETED SSC 9LA PER GUIDELINES INCLUDES WASH
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~INSPECT AND REPLACE ENGINE AIR FILTER IF NEEDED ~|~ ~|~REPLACED ENGINE AIR FILTER
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~PLEASE REPLACE OIL AND FILTER FBK....RBK....RF....LF....RR. ...LR....MAINT....ACF....NCI. .. ~|~ ~|~COMPLETED OIL AND FILTER CHANGE
15455 MILES
DATE 10/2008
SERVICE: GUEST TO MEET WITH LEXUS REPS
DESCRIPTION: GUEST TO MEET WITH LEXUS REPS ~|~C/S THERE ARE MARKS IN THE PAINT ON THE ROOF AND THE HOOD. PLEASE CHECK AND ADVISE ~|~INSPECTION ~|~GUEST TO MEET WITH LEXUS REPS
SERVICE: MILEAGE OUT AT COMPLETION:15455
DESCRIPTION: MILEAGE OUT AT COMPLETION:15455 ~|~NOTE TO TECHNICIAN: PLEASE DOCUMENT MILES OUT UPON COMPLETION OF ALL WORK ~|~15455 ~|~MILEAGE OUT AT COMPLETION:15455
SERVICE: PER GUESTS REQUEST, CONTACTED LEXUS ON THEIR BEHALF. LEXUS AUTH TO SPLIT COST OF
DESCRIPTION: PER GUESTS REQUEST, CONTACTED LEXUS ON THEIR BEHALF. LEXUS AUTH TO SPLIT COST OF ~|~C/S 2 TIRES ARE SHOWING ACCESSIVE WEAR ON THE INIDE ~|~GUEST CAME IN WITH CORDS SHOWING ON TWO OF HIS TIRES AND EXCESSIVE WEAR ON TWO. GUEST UNHAPPY WITH T… READ MORE
SERVICE: PERFORMED 4 WHEEL ALIGNMENT
DESCRIPTION: PERFORMED 4 WHEEL ALIGNMENT ~|~PERFORM 4 WHEEL ALIGNMENT ~|~ ~|~PERFORMED 4 WHEEL ALIGNMENT
SERVICE: REPLACED ALL 4 TIRES WITH MICH. DOT HNNP J43X 3808
DESCRIPTION: REPLACED ALL 4 TIRES WITH MICH. DOT HNNP J43X 3808 ~|~C/S THE TIRES ARE SHOWING THE CORDS ON THE INSIDE ~|~BELT ARE SHOWING ON INNER EDGES OF TIRES ~|~REPLACED ALL 4 TIRES WITH MICH. DOT HNNP J43X 3808
5640 MILES
DATE 05/2008
SERVICE: APPOINTMENT BOOKED BY DANA
DESCRIPTION: APPOINTMENT BOOKED BY DANA ~|~W051208LB
SERVICE: LOF-9 OIL LUBE AND FILTER SERVICE SERVICE FULL SYNTHETIC MOTOR OIL.
DESCRIPTION: LOF-9 OIL LUBE AND FILTER SERVICE SERVICE FULL SYNTHETIC MOTOR OIL. ~|~LOF-9 OIL LUBE AND FILTER SERVICE SERVICE FULL SYNTHETIC MOTOR OIL. ~|~ ~|~5640 COMPLETED. 0.5 TECH 400
SERVICE: ROTATE AND BALANCE 4 TIRES.
DESCRIPTION: ROTATE AND BALANCE 4 TIRES. ~|~ROTATE AND BALANCE 4 TIRES. ~|~ ~|~5640 COMPLETED. 1.3 TECH 400
SERVICE: SEE SERVICE ADVISOR
DESCRIPTION: SEE SERVICE ADVISOR ~|~CUSTOMER STATES HAS TOUCH UP PAINT IN PARTS
SERVICE: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
DESCRIPTION: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~|~PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~|~REQ ~|~18 REQ COMPLETED PDI 2.0 NOTE: STARTING MILEAGE WAS 5, NOT 17
