Blessing from the car gods
So along with fixing an exterior trim piece today i went ahead and took out the glove compartment to see how bad i was screwed with that blend door thing for the AC.
I had gotten the Lex about 2 months ago and when i read about the cabin air filter "issue" i knew i had it before i even needed to replace it lol
So...
THANKFULLY the arm just separated out of the joint.
I carefully re-attached the arm, double checked that the door worked and replaced the filter. Smooth like Keith Stone.
Thanks to this site I was able to diagnose the issue!
So...
BlazeViper (09-24-21)
Every time you turn on the car, it reset to 75, never keeps the same temp. That is normally the sign of it. I had the issue on my 2007. About 2 hours to pull the dash apart (there is a DIY on it, very easy, just take your time), popped it back on all fixed..
Jonathan01
04-15-21 06:17 PM
