Noise from rear.
Most likely. Haven't had time to check it out. Certainly vibrates a lot from that area.
Here's a video about parking brake problem https://www.youtube.com/watch?v=RURTrJWJGh8
But it sounds like your issue is more likely related to brake Hold system if active or accidentally activating. E brake shouldn't be working while starting and stopping. I think you should pull the wheel and have someone watch the brakes while another operates the car, simulating the conditions of stopping and starting.
Does your car have the feature that uses brake-pressure to hold it when stopped on a hill? Sometimes, when starting off, you'll hear a short hum or wheezing-noise for a second or two as the electrical-linkage is released...particularly if it uses the emergency brake for the roll-back-hold.
