LS600HL Alarm, VSC, Brake, and PCS light PLEASE HELP
Hello Fellas,
I haven’t posted in a very long time. I have an 08 Ls600hL. I started seeing the Red “BRAKE” light turn on from time to time as I drove. A day or two later, I opened the car’s door and w/o even starting the car, there was an alarm going off. As soon as I started the car I have PCS, VSC, and BRAKE lights as well as an alarm coming from the dash/cluster area.
the car goes into gear, it drives, and after a minute or two, all the lights turn off except for the intermittent red “BRAKE” light.
if I turn the car off and start it right away, it’ll start w/o any alarms nor lights.
I tested the battery with the car off and it has 12.6 volts. I disconnected the battery and reconnected it but the issues remain.
I tightened the gas cap but nothing. I’m buying a new gas cap.
please any help. Has anyone have this issues at the same time?????
thank you in advance
85Krtagena (10-11-21)
i thought about this. But didn’t think it would show anything since the lights/alarms go away by the time I get there. I’ll see if I can find an OBD2 scanner
There may well be stored codes.
The only time I have seen the alarm / red brake light on, without starting the car, is when the dc brake motor went bad. I believe when there is no brake pressure, or when the pump is commanded on with no increase in pressure the alarm sounds regardless of whether the car is on. I suspect your brake motor is going bad although it could be a sensor, low fluid, relay, ect. It is not safe to drive imo.
The following 2 users liked this post by miket000:
BlazeViper (10-12-21),
swfla (10-12-21)
Redeemed07
08-15-18 11:26 AM
MSGX470
GX - 1st Gen (2003-2009)
07-28-13 07:44 AM
