Extended Warranty Advice
Hi All,
I am looking for some advice here. I have never owned a lexus before, so this is my first lexus. About a week ago, I bought a used 2008 lexus ls460 with about 155000 miles on it. The vehicle is in really great condition and was well maintained. The only imperfections is the passenger headlight housing that has some condensation inside of it after I got the car washed, and the low beam bulb is out. I ordered the bulb, and plan to replace it myself.
I am currently thinking about getting some extended warranty for it, but the coverage I am seeing includes the following; engine, transmission, turbo/supercharger, drive axle assembly, Electrical, modified vehicle coverage (lift kit/tires), VIP Anniversary Pak. This would all cost about $1000 for 36000 miles over 3 years. Do you guys think that this is a reasonable price or not? Or should I not worry about extended warranty given how reliable this car is?
Thanks for your advice in advance.
You want to make sure there is not anything weird written into the warranty and that you can use it at a Lexus dealer with Lexus parts. It also should cover the high pressure fuel system and brake actuator as well if you can find one that covers that as those are quite pricy to fix
Persocon (10-27-21)
Thanks @Striker223. I am actually looking for a better coverage that covers the components that you mentioned, but I have not been able to find one since the car is too old. If you happen to know any good coverage out there, please let me know. Thanks
The one I am thinking about getting shows pretty much anything that is not included in the coverage. The only items that are included are the ones that I listed in my initial post.
I am thinking that I may not need the coverage, unless it covers the components that are more likely to fail.
A friend was interested in buying a '08 LS460 with 145K miles, extremely clean but without a warranty. He had it inspected at a local Toyota dealership. Worn control arms/bushings and $6100 to replace. RIDICULOUS! Toyota/Lexus must be extremely proud of their parts. He's looking for something better.
Parrokeete (10-31-21)
LS460 is very expensive to maintain. One of ways to reduce the cost is to do all labor by yourself. Parts are expensive because LS460 shares very little parts (that tend to fail) with other Toyota/Lexus cars.
You are right. He said the arms listed for $185 and most of the $6100 is labor and included a 4 wheel alignment. The LS had a oil leak from the valve cover gasket and a worn front shock that wasn't included in the estimate. He passed on this LS.
