Updated control arms
I remember seeing a thread about some updated front control arms that lasted longer than the OEM and I think it was here on CL. I had it bookmarked but on that computer the hard drive failed when the lithium battery went awry (It just smouldered thankfully).
Do any of you remember that article? I think it had a full list of updated parts. I've tried different search terms but have not found it using the forum search tool.
Thank you in advance,
Jeffrey
Jeffrey
barloewen (11-15-21)
And a couple more that reference the newer OEM lower rearward arms for RWD models: Polished the Revised Control Arms - Lower Rearward - ClubLexus - Lexus Forum Discussion
DIY LS460 engine mounts and control arm bushings replacement - ClubLexus - Lexus Forum Discussion
Protholl (11-14-21)
I have a 2007 LS 460 and put in the updated arms last month with no problem. They seem to be performing fine. Have been getting the OEM arms from Impex Japan for high hundreds, low two hundreds range.
48640-50131
48620-50131
48640-50131
48620-50131
Protholl (11-18-21)
did you get a front wheel alignment after the CA replacement? thanks,
scutch (11-19-21)
I have only done the shocks and the two main lower control arms, with the new design for the 2012s and newer. My guy said he tested the alignment and it was fine afterwards. It was fine when I drove it.
I am doing the rest of the front control arms next, and those godforsaken ball joints that you have to buy the whole steering knuckle for to get OEM. I have attached my invoices. I am paying $122 for shipping on this latest order from Japan because those steering knuckles are heavy. It has been more like $40-$60 in the past. I have no idea why the upper control arms are more expensive than lower. you'd expect the opposite.
Jeffrey
Jeffrey
what site are you buying this stuff from
I am using https://en.impex-jp.com/
Impex Japan.
A company in Japan run by Russians. This next one will be my 3rd purchase from them. The process takes about 2-3 weeks till you get parts in hand but they are OEM and 40-60% cheaper than I can find them in the US.
After I get this next shipment, I was going to write up a quick message on them because you can save money, but their website and process is fairly confusing at first. Thankfully, they are good at answering questions by email.
Impex Japan.
Jeffrey
Jeffrey
Protholl (11-19-21)
At first I decided that I would get the OEM bottom control arms and aftermarket upper ones. But when I got the 3 Mevotech arms from Carid and compared them to one of the OEM uppers I got on Ebay, I decided to just bite the bullet and get the OEM. The rubber boots over the ball joints seemed flimsier, and when I moved the ball joints around in a circle the OEM ones were smooth flowing and firmer and the Mevotech ones had some resistance at some angles. Not very scientific, just my observations. I just only want to do this job once for the life of my car, now at 175k miles. Hoping OEM will make the difference, and making sure my mechanic torques the control arm bolts in driving position, and not with the wheels hanging down when on a lift. That has been mentioned in a few posts as to why some of the control arms fail quickly after replacement.
Megazip is ran by russian speaking people as well. I had no complains about their service or products. I believe, Amayama is also ran by russian speaking people. However, both sell OEM japanese parts out of Japan and Emirates.
They are unusually professional from every experience I have had. Sometimes they can be slow but I have never once had an issue with receiving exactly what it is I bought in perfect condition/exactly as described.
scutch (11-19-21)
