Windshield Question
Windshield Question
So it might be time to replace the windshield. Thing is they changed part numbers and from where I usually buy my stuff the new numbers are more expensive than the old part numbers. Is there a difference?
so some questions:
I know that basically I need one with auto rain sensing. I don’t know if I have de-icer I need to check.
1. there seems to be few main variants. Ones that say LAM, which I guess stands for laminated, green blah blah with various options and LAM blue.
2. then there’s also EHL, which I have no idea what that stands for.
3. other than the cut outs for the pre Collision camera, if I find one for a good price there’s no reason I cannot install that right ? Maybe there’s even a way to rig up the de-icer
so some questions:
56101-50770; 56101-50450; 56101-50451 with rain sensor
56101-50760; 56101-50540; 56101-50541 with cold area package
56101-50750; 56101-50510; 56101-50511 with rain sensor and cold area package
I believe, EHL stands for "Electronically Heated Laminated" meaning it has a deicer.
Can't help you with this specific question, but I'm interested in the answers.
My original windshield has survived rocks with only a very small spider web, which is impressive for the roads here. However, it could not survive being hit with sand at 140kph. It now "sparkles" if the light hits it just right with all the sand pitting. Lesson learned.
I assume I can probably have someone pull a used windshield from a junkyard? A new factory one here would likely be very expensive, and an aftermarket one will probably be junk since windshields are basically a maintenance item here.
I’ve seen factory one 300+ 5610150760
*EHL,T=5.48,GREEN,SIDE GLASS-LAMINATED&WATER REPELLED&WINDSHIELD DEICER-WITH&INTERMITTENT WIPER-AUTO(RAIN SENSOR)
Cardon: 11,552 Uah which is 300-400 usd
its shipped from some place tales 20+ days.. there’s no reason to get a non factory one unless you have a lka etc that variant is 1000 usd.. I need to plan how to wire the deicer if at all possible.
Yes, glass itself is usually 200-500 range. 760 one is from 13+ cars but 750 and 760 are compatible (but don't quote me on that - there are nuances). Also sharing a bit of a secret here. 13+ glass w/deicer have one staggering improvement over original. That's all I'll say.
Ok just checked m-cat - current correct replacement windshield for most LS4s is:
(my 760 got blue top. m-cat may have an error here saying 'green top')
56101-50760
It it a modded windshield well worth replacing to esp in cold climate areas as it got a neat mod compared to earlier glass (part no).(my 760 got blue top. m-cat may have an error here saying 'green top')
jdanielca (11-29-21)
