DRL on LS600 headlamps
Dear all,
Have owned my LS600hL for 2 years and it has been a fantastic car in terms of reliability and comfort compared to 7 series and the S class. Huge fan on the LS 4th gen!
My headlamps DRL are flickering with blue lights. Rest of the headlamps are working perfectly. Does any one know if the DRL can be repaired?
Many thanks
Many thanks
It seems like a lot of 2013 MY headlights are starting to have this issue. Unfortunately the only way to fix this is to take all the screws holding the lens together, and then bake the light, usually in an oven.
That should soften the butyl sealant and allow you to pull the lens from the housing and get in there to fix it. Watch any headlight opening procedure on YouTube. The process is all the same.
