Seems to be a starter circuit issue...
In my 2009 LS460 I press the brake and get the green light on my start button (normal) and the car cranks for a moment, not long enough to start. I press the button again and get nothing yet all the while my dash light are on, etc. I let the car sit a while and the same thing happens again. Evidently the starter is working so my question is: what is in the circuit that tells the starter to disengage thinking that the car has started? It seems there is a fault in a sensor that talks to the starter. I removed the starter relay and bench tested it and it's fine. What else??
You may not be reading my replies, I shared that the battery, starter and starter relay are good, what am I ignoring??
You need techstream or a good code reader in order to diagnose it further.
miket000 (03-31-22)
