Seems to be a starter circuit issue...
In my 2009 LS460 I press the brake and get the green light on my start button (normal) and the car cranks for a moment, not long enough to start. I press the button again and get nothing yet all the while my dash light are on, etc. I let the car sit a while and the same thing happens again. Evidently the starter is working so my question is: what is in the circuit that tells the starter to disengage thinking that the car has started? It seems there is a fault in a sensor that talks to the starter. I removed the starter relay and bench tested it and it's fine. What else??
jmcraney (03-29-22)
Cleaned the posts and charged it overnight. I'm looking for circuit/schematic level input. Please keep in mind, if the car sits it cranks momentarily. this tells me that there is some sort of a reset in the circuit, the same circuit that tells the starter to disengage as if the car has started. The simple stuff has already been done. Thanks
It cranks normally for about 1 second, I let it sit a while and it cranks for one second again. Something (a sensor, computer, etc.) is shutting down the starter for a while then letting it work again.
I think the advice from jud149 in post #4, above, should be your next move. Have your battery tested by a battery dealer.
The battery is ok, I need to look at components withing the starter circuit. I'll ask a more detailed question: what component in the starter circuit tells the starter that the engine has started and to stop cranking? In a keyed car we simply hold the key in the start position until it starts, in a push button car this is done via sensors, etc,. What is that component? Thanks
The engine computer does this based on the various inputs/sensors. "The battery is ok" is you guessing get it tested.
Jump the starter relay, see if the starter really spins for longer than a second.
Battery good, pulled the starter relay and jumped the terminals, starter turns great with lots of power. Starter relay tests good so it comes down to another component in the starting system.
miket000 (03-29-22)
After checking the simple basics, I'm thinking a module/cpu or it's connector. Intermittent might be either. Maybe someone has the diagram you're requesting, but I suspect it will show a module between the start button and the starter. I wish I knew which module and where it's located. If your code reader didn't show a problem, going to a shop with Techstream software may give you an answer. Techstream is Toyota/Lexus specific software.
