Oil not registering on dipstick after recent oil change.....
Positive he put correct amount of oil in it. I'm going to check it again a week from yesterday to see how much it's consuming in a week, miles wise.
Yep, you're right. 3 quarts low = oil light on. I'll tell you what, it's obvious a huge problem if my car is eating that much oil, on a lesser note, hearing/seeing that beep notification every time the Low Oil light comes on is annoying as ****. Especially when it's every few minutes. Although very necessary of course. Haha. It's a reminder that says to me, "I know, I know, this sucks, quit reminding me." 🙄🤣
I think it comes on at around 2-3 QTs low for a 460, overall amount in the pan is about 9.0-9.7. They hold massive amount of oil for a non-diesel engine that's for sure.
EDIT: Checked my manual, from the low dot to the full dot it's 1.6QT/1.5L and the warning light is 2-3QTs low
I know it's premature to ask this question before finding out the issue. But how in the hell does my car go from not burning any oil to BOOM, huge consumption?
One poster mentioned he experienced a similar issue directly after a valve corner replacement.
Sorry for the rant, I'm irritated. I love my car!!! Best car I've owned and I'm proud of it. You guys have been great. Very responsive and helpful. Thank you. 😀
Just at least check the oil filter housing so you know you do not have a pressure side external leak
Thank you Stryker. No leaks that I can visibly see.
I sent a screenshot of your post to my mechanic to give him things to look at.
He's going to look at it the following weekend. He said he's seen my same car come in that was losing 2 quarts per week. He mentioned something about piston rings and in her case possibly needing an engine rebuild. Ugh.
Well, I'll wait and see.
Have you yourself looked around to make sure you don't have a leak? You had the top 1/2 of the engine apart after all and there are a lot of oil seals there, also confirm PCV operation is correct since if you had a air ingress point somewhere else and now it is sealed a bad pcv would start working again and possibly start consuming a lot of oil. If you were not having this issue before I doubt the rings went bad like an on/off switch, I would start by confirming all other related systems to the repair you just did.
You can check spark plugs, if one of cylinder is burning oil, you should be able to tell it by looking at the spark plug.
Also, check your coolant for presence of oil, just in case. In between, these engines have a history of leaky piston rings in early production years.
NotFasty (04-07-22)
Dudes. Some c-nt obviously skipped pouring oil in / underfilled (e.g. ls430 takes only 5qts).
swfla (04-07-22)
He changed the spark plugs and flushed the coolant a couple months ago.
It is not what I meant. If any of spark plugs is foiled that means that the engine is burning oil rather than having an external oil leak.
Occam's razor, innit, Striker...
The following 2 users liked this post by Boykie:
NotFasty (04-08-22),
Striker223 (04-07-22)
