Lexus LS600HL
Why not remove the seat bottom and investigate? There are several Youtube videos on how to do it, very easy. Also, plug in the OBD port for codes. If it's an essential system part like the battery, it'll show a code.
Sounds like you have an exposed wire.
Cape600L (05-08-22)
So I found water under the passenger cushion. I’m assuming that may have caused and arc in the wires but I didn’t see any burnt wires. I started it up with the seats out and no smoke. The fuel pump access is the culprit I’m guessing. Anywhere else water may be coming from in that area?
I am sorry, I take that back. However there is AC drainage under that seat. There is a picture of the drain visible from underneath - https://www.clublexus.com/forums/ls-...ml#post6415793
I found out the issue!!!!! So the sunroof drain I think is clogged and it was leaking water somehow onto the rear defroster wire. The rear defroster wire is pretty burned up. How do I clean sunroof drain hose?
Weed wacker line, you can get a roll for like $5 or so and it is easy to feed through every drain
swfla (05-18-22)
