i've just purchased some wheel for my 460 and while i wait for them to arrive i was looking at new lug nuts. can someone please tell me what size/pitch i need? also hub centric ring? my new wheels have a bore hole size of 72mm does anyone know what rings i will need as well
thanks in advance
thanks in advance
They will require 60.1mm hub centric rings. Lug nut size is M14x1.5
I've been running these on my LS for 3 years now without any issues:
is that even if they are aftermarket wheels or just for stock?
Any pics or info of the wheels you can post? I believe the majority of aftermarket wheels use conical/tapered style lug nuts these days. My spare is the OEM wheel, so I keep a set of the OEM lug nuts in the trunk with it. Check this out and also do your own search to verify, is my best advice. https://www.townfairtire.com/informa...es/index.shtml
it's all sorted now, got the right lugs and hub rings. wheels haven't arrived yet but they are 20x8.5 et35
super excited to change out the stocks.
cheers for all help
Good looking wheel design.....sport elegance with a darkside edge.
And relatively easy to keep clean/wash. I hope you'll post pics once you get them on the car.
