Does anyone have the approximate weight for the 2013 + hollow chamber wheels or any experience on how much better these are than the standard 18 inch wheels from pre face lift
They are far far better, the hollow chambers eliminate tire reverb noises. Weight is basically the same, lightest stock rims you can get are the F-sport BBK rims followed by the 18s
Thank you for the information. Do the hollow chambers reduce noise on bump impacts as well?
Having driven LS460s with and without these wheels, I don't notice any difference personally.
Thank you I have read your other post regarding difference in ride quality between 18s / 19s and agree with your thoughts unless the hollow chambers give me something special I will save the money
I also wondered the weight savings if any of the hollow spokes. As mentioned they probably use more material as the goal is the reduce noise rather than weight. Would love a set either way.
