New Executive 460L, failure of rear struts , need advice thanks
Old 08-28-22, 08:03 PM
miket000
miket000's Avatar
I recall an old post in which the rear of a car fell to the ground. Apparently both air lines have a common joint near the back. I think access sucked if I remember correctly. His joint cracked, car was dragging. I think he had his family in the car early into a few hour long drive. He had to turn back.
Not at my pc so searching is limited.
Found it. https://www.clublexus.com/forums/ls-...l-failure.html
Gerf (08-28-22)
Old 08-29-22, 04:09 AM
Vansibel
Vansibel's Avatar
Also, third post: https://www.clublexus.com/forums/hyb...l-dropppp.html
Old 08-29-22, 05:18 AM
Anfanger
Anfanger's Avatar
I think, it is important to determine if the pump is constantly running. If it does that means there is a leak somewhere after the valve(s). If it does not, than the valve(s) might be the cause.
swfla (08-29-22)
Old 09-01-22, 11:28 AM
1WILLY1
1WILLY1's Avatar
thanks alot guys, going to my indy tech to see if it shows any codes,, if not i may go to dealer ..ill definitely update and appreciate all the help
swfla (09-01-22)
Dryrunner
07-14-24 01:38 PM
demark1
12-20-22 01:00 PM
xinkid
04-16-12 09:10 PM
python
19
10-19-11 08:06 AM
Quick Reply: New Executive 460L, failure of rear struts , need advice thanks
