ls600 the engine does not start
7th Gear
I lent the car to a friend who drove it into a hole.Probably good because I have an egg from the bike.After that, she drove about 300 meters and the car lit up like a Christmas tree. Lots of mistakes.We managed to delete them several times via mobile phone.the car then continued for a few km when it again announced a lot of errors.I deleted the errors again and it happened like this several times before I got home.At home, I then tried to connect to the ToCom diagnostics.Then the car drove away again.But then they couldn't delete the errors - that is, the car always tries to start, but the engine immediately shuts off and it announces the errors.Thank you for any advice and help.
Car Scanner ELM OBD2
DTC report
Selected brand: Lexus
============1==============
P0358
Raw code: 0358
ECU: Řídicí jednotka motoru
Stav: Potvrzené
OBDII: Ignition coil H, primary/secondary - circuit malfunction
Lexus: Ignition Coil H Primary / Secondary Circuit Malfunction
============2==============
P0A0F
Raw code: 0A0F
ECU: 7EA
Stav: Potvrzené
OBDII: Hybrid drive system - engine failed to start
============3==============
P0358
Raw code: 0358
ECU: Řídicí jednotka motoru #1
Stav: Potvrzené
============4==============
C1259
Raw code: 5259
ECU: Řídicí jednotka ABS #2
Stav: Potvrzené
============5==============
C1310
Raw code: 5310
Stav: Potvrzené
============6==============
P0A0F
Raw code: 0A0F
ECU: Hybrid engine system
Stav: Potvrzené
============7==============
P0A0F
Raw code: 0A0F
ECU: Motor generator
Stav: Potvrzené
============8==============
C1259
Raw code: 5259
ECU: Power steering
Stav: Potvrzené
============9==============
C1310
Raw code: 5310
ECU: Power steering
Stav: Potvrzené
============10==============
B2090
Raw code: A090
ECU: Pre-collision safety
Stav: Potvrzené
============11==============
C1641
Raw code: 5641
ECU: Self-parking system
Stav: Potvrzené
============12==============
C1646
Raw code: 5646
Stav: Potvrzené
============13==============
B1421
Raw code: 9421
ECU: Climate/Heater
Stav: Potvrzené
Lexus: Solar Sensor Circuit (Passenger Side) (Progr., RX3))
============14==============
B1424
Raw code: 9424
ECU: Climate/Heater
Stav: Potvrzené
Lexus: Solar Sensor Circuit (Driver Side) (Progr.)
============15==============
B1428
Raw code: 9428
ECU: Climate/Heater
Stav: Potvrzené
============16==============
C1A40
Raw code: 5A40
ECU: LKA/LDA
Stav: Potvrzené
DTC report
P0358
Raw code: 0358
Stav: Potvrzené
P0A0F
Raw code: 0A0F
ECU: 7EA
Stav: Potvrzené
P0358
Raw code: 0358
Stav: Potvrzené
C1259
Raw code: 5259
Stav: Potvrzené
C1310
Raw code: 5310
Stav: Potvrzené
P0A0F
Raw code: 0A0F
Stav: Potvrzené
P0A0F
Raw code: 0A0F
Stav: Potvrzené
C1259
Raw code: 5259
ECU: Power steering
Stav: Potvrzené
C1310
Raw code: 5310
ECU: Power steering
Stav: Potvrzené
B2090
Raw code: A090
Stav: Potvrzené
C1641
Raw code: 5641
Stav: Potvrzené
C1646
Raw code: 5646
Stav: Potvrzené
B1421
Raw code: 9421
ECU: Climate/Heater
Stav: Potvrzené
B1424
Raw code: 9424
ECU: Climate/Heater
Stav: Potvrzené
B1428
Raw code: 9428
ECU: Climate/Heater
Stav: Potvrzené
C1A40
Raw code: 5A40
ECU: LKA/LDA
Stav: Potvrzené
It looks like a power related issue. I would start with the battery terminals and move to ground wires and poorly connected wire harnesses.
7th Gear
[QUOTE=Anfanger;11360533] Vypadá to jako problém související s výkonem. Začal bych s svorkami baterie a přesunul se k zemnícím vodičům a špatně připojeným kabelovým svazkům. [/CITACE]
I checked the fuses, all the connectors that were accessible, but I found nothing.....
I'll suggest some guesses... Since you mentioned it hit a bump. You could disconnect the power steering rack (unplug it) then see if the engine stays running. Have you tried to reset the hybrid disconnect switch in the trunk?
7th Gear
miket000;11362134]50 second mark
Thank you.Since I am translating from Czech through a translator, it is more difficult to find something.I unplugged the switch but it didn't help.I didn't try to disconnect the steering rack, I didn't understand whether I should disconnect somehow mechanically or just some cable.please specify.Thank you very much.
You're welcome. If your power steering is working normally i'd guess there is another issue. I was suggesting to unplug the cable's off of the steering rack if you think it may be the cause. I would not disconnect it mechanically. How big was this bump the car hit?
7th Gear
Nahráno "19.9.2022" v "7:45:03" | Ulož.to (ulozto.cz)
miket000 (09-19-22)
7th Gear
DTC report
P0A0D
Raw code: 0A0D
ECU: 7EA
Stav: Potvrzené
OBDII: High voltage system - interlock circuit high
C1203
Raw code: 5203
Stav: Potvrzené
Lexus: ECM/TRC communication Circuit malfunction / 53 (RX, LC)
C1259
Raw code: 5259
Stav: Potvrzené
C1310
Raw code: 5310
Stav: Potvrzené
C1345
Raw code: 5345
Stav: Potvrzené
P0A0D
Raw code: 0A0D
Stav: Potvrzené
P0A0D
Raw code: 0A0D
Stav: Potvrzené
C1203
Raw code: 5203
ECU: Power steering
Stav: Potvrzené
C1259
Raw code: 5259
ECU: Power steering
Stav: Potvrzené
C1310
Raw code: 5310
ECU: Power steering
Stav: Potvrzené
C1345
Raw code: 5345
ECU: Power steering
Stav: Potvrzené
B2060
Raw code: A060
Stav: Potvrzené
B2090
Raw code: A090
Stav: Potvrzené
C1641
Raw code: 5641
Stav: Potvrzené
C1646
Raw code: 5646
Stav: Potvrzené
B1421
Raw code: 9421
ECU: Climate/Heater
Stav: Potvrzené
============17==============
B1424
Raw code: 9424
ECU: Climate/Heater
Stav: Potvrzené
============18==============
B1428
Raw code: 9428
ECU: Climate/Heater
Stav: Potvrzené
============19==============
C1A40
Raw code: 5A40
ECU: LKA/LDA
Stav: Potvrzené
the wheel (bike) has a severe dent. It's likely that a computer module that is connected to all errors is involved. Either a connector is loose or the main module is damaged. Try this, clear all the codes. Maybe the car will start. Some codes may come back immediately and others may take 100 miles to show up again. You really need to have a technician diagnose this for you. It could be many things wrong or just one thing. If you don't have Lexus, then go to Toyota.
7th Gear
