Hoping someone is more familiar with the Autel diagnostic tablet
I recently did some suspension work on my 2010 LS and now I notice that one rear corner is about an inch higher than the other side. I’ve tried to adjust the height sensor with no luck. I also tried on my Autel diagnostic tablet and it appears to have the functionality to adjust the height sensors but I run into an odd error. See attached photos. If anyone has experience with this, please chime in. Thank you
Error is (ugh) correct. Looks like Autel just copied oem procedure. For that you need measured values, those are in FSM for correct MY etc. It's considered a bad practice to use those as well, those are just for minute adjustments. You set correct vehicle height using sensor links adjustment.
