Hey guys I recently got a c1377 code for capacitor so i swapped out the power supply in the trunk with 89680-33010 another one. Fired up the car and check parking brake light still there so I tried to do the relearn linear valve offset with techstream like I did when I had to replace the other brown brake module. Now the ABS VSC & BRAKE light is on!
Anyone ever run into this issue or have any insight? Im assuming linear valve offset cant be completed because theres still an issue with my parking brake so it threw those additional lights?
I had that capacitor code a year ago but it cleared by itself. Is that a current fault or history? I think the parking brake system is independent of the regular brakes.
I replaced the same module 2 years ago with sucess just like you. I only had the additional abs vsc and brake after i tried repgrogramming the new power supply.
The parking brake and regular brakes maybe independent but the linear valve offset and i believe reset memory rely on the parking brake being engaged/disengaged
I'm not familiar enough with the inner workings to answer your question. There is a certain sequence to follow to clear brake codes. I would start here.
