LS 460 Losing track of FOB
2nd gear
This just started happening in the past week or two. 2010 LS460L. First sign of issue was display saying FOB battery was getting low. Next day car is completely dead. Thought maybe one of my kids left a cabin light on so charge the battery overnight. Once charged, no interior lights are on, and car starts just fine but beeps when I turn it off and close drivers door. Not sure why at the time and dismiss it. Early the next morning I get out of the car when it's still dark and notice that the interior courtesy lights and push start light are flashing after I leave the car, which still beeps. Then I realize that I can't lock/unlock the car from the touch handle or from the FOB and if I try to lock it from the door it immediately unlocks itself. At this point I've already replaced the FOB battery with no changes. The car never tells me it can't locate the key when I'm sitting in the drivers seat and it starts up just fine with the FOB in my pocket. I believe I may have a faulty oscillator, and that the car knows when the FOB is inside but does not know when it leaves so it thinks the keys are left in the car.
Has anyone seen this before? Am I correct in thinking it's an oscillator?
Logic tells me if it is an oscillator then it's probably the drivers side. Has anyone had any luck replacing one?
I'm not against taking it to the dealer if I have to, but I usually do all my own maintenance and would rather do it myself if it's possible.
Thanks for any help!
I'd hook up an OBD reader to check for codes, that's almost always the first diagnostic step. The door jamb switch is notorious for creating all sorts of odd problems. You can check that with a multimeter. You can also disconnect he car battery for an hour, this will reset some issues. Not saying my suggestions are a definite fix but they are cheap and easy to do yourself. I have also experienced an old stock/low voltage battery purchased from Ebay or amazon for my key fob. Buy from a vendor or store with high turnover rate.
Anfanger (01-09-23)
joedaddy1 (01-09-23)
I believe the common issue is faulty switch, not a dirty switch. But try a spray cleaner and let us know if it helped.
2nd gear
This is great advice. Thanks.
Quick update: Battery had been dead for a couple of days so I charged it overnight. Hooked up my OBD2 scanner and realized I could scan the key system ECU with the app Carista that I have. Did not pull any codes. Door jamb switch seemed to be working but I agree that it is a very likely culprit for these symptoms. Anyway, while going over these troubleshooting steps I noticed that everything was working right again. I'll have to keep an eye on it but for now its working.
Redfire03
04-05-10 05:49 AM
