LS460 courtesy Light Fuse
Old 01-19-15, 03:18 PM
Tom11x
Tom11x's Avatar
Default LS460 courtesy Light Fuse
Does anyone know which fuse is for the Rear door courtesy light is at? The front is working but the rears are blown. Thanks
Old 01-19-15, 03:50 PM
jmcraney
jmcraney's Avatar
We can't tell from your post if this is a power issue, or maybe something else. Defective Door Jamb switches are a common problem on many of the LS460s. The most common manifestation of a defective door jamb switch is the failure to sense an open door and turn on the courtesy light.
We have discussed this in several threads. If you will follow this link it will take you to a post that has links to several discussions that might help you if it turns out that it is not a fuse problem.
https://www.clublexus.com/forums/ls4...ml#post8856567
Old 01-19-15, 03:55 PM
Tom11x
Tom11x's Avatar
I was wiring something up that was connect to the door lights. The fuse is bad but can't find the spot
Old 01-19-15, 08:58 PM
CJITTY
CJITTY's Avatar
I'm thinking its the fuse panel behind the trunk liner on left side near taillight..if its the same issue I had. But one fuse shut down my entire rear armrest controls and trunk courtesy lights
Old 01-20-15, 07:33 AM
roadfrog
roadfrog's Avatar
If you blew a fuse, there will be other non-functioning accessories in your car. There is no dedicated fuse for door lights and are tied into other things like door locks, fuel door, etc.
That said, it will be one of these here:
On the passenger side cowl:
On the driver's side cowl:
In the trunk:
RobLambo
11-03-14 06:48 AM
HyadMusic
SC- 1st Gen (1992-2000)
06-15-14 01:52 PM
michaelw
GS - 1st Gen (1993-1997)
01-19-14 10:37 AM
N1T3MARE
Maintenance
07-12-09 06:37 PM
rainman49
10-21-06 07:06 AM
Quick Reply: LS460 courtesy Light Fuse
