Michelin Crossclimate Tires
#31
I just purchased the Michelin Cross Climate II's for my 2023 LS500 and the ride is so much better than the run flats. For what its worth, the run flats cannot be driven on if the sidewall is damaged. The wheel is about a 1/4 inch off the ground and will get damaged. Mine was cut in a car wash by the tracks on the floor and instantly deflated. I ended up getting flat bedded to prevent wheel damage. I highly recommend the Michelins.
Crazy a car wash could do such damage to a tire!!
#33
not seeing it on Tire rack as an option for base in either size.
That does not mean its no available.
My choices were down to Michelin Primacy or the Bridgestone Quiet track. Can you tell us a bit about the Hankook's and why your considering them?
Nalod (08-08-24)
#36
I'm running a staggered setup with Michelin Latitude Sport 3 (RF) and imho they're comparable to the Pilot Sport 4S I've had on other cars. I highly recommend them and will continue to use them in the future unless Michelin introduces something better.
fabchef
08-22-21 04:38 PM
