Apple CarPlay Retrofit soon?
#151
Service Bulletin - https://static.nhtsa.gov/odi/tsbs/20...62736-9999.pdf - use it there is an additional photo about files on usb!
Updates - https://drive.google.com/drive/folde...kACDpPj0GHAkxB
Basics:
-Use a high quality 8GB flash drive
-Drive *MUST* be formatted in Windows using FAT32
-This update will stress the drive and may overheat the flash drive causing the update to fail.
-You may use any USB HDD/SSD, as long as the first partition is MBR, 8GB, FAT32
-Most common issues are flash drive read errors, overheating, and format issues
-The documents explain the recovery methods
Basics:
#152
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
unfortunately, the information about the update of the European ls500 was not confirmed, other models received updates, in your case you can install the wireless carplay module,it can be done in Warsaw
#153
no, these updates are only for the market of Canada, the USA and Mexico, what is written in the bulletin, but in general they differ in the system number itself, so you need to look at the bulletin, they put other electronics in Europe, so the update does not work, maybe your electronics are different
#154
#155
Does anyone know more information about whether there has been an update for the European market? my car has the following software.
LS500h 2018 F-sport
Modell-ID DCU 17LDL2EU-DB01
Modell-ID MEU 17LML2EU-FB00
LS500h 2018 F-sport
docmarioce
09-24-15 06:31 AM
Sal Collaziano
03-13-08 01:02 PM
