Valet Mode
The screen can be locked so that personal information such as the user's home address cannot be viewed. When locking the screen, the user enters 4 numbers. Entering the same 4 numbers unlocks the screen.*1
HINT:
*1: If the wrong code is entered 6 times while attempting to unlock the system, no codes can be entered for 10 minutes. In this situation, wait 10 minutes or more, and then enter the code again. However, if the code is forgotten, the screen can be unlocked using the Techstream.
HINT:
HINT:
HINT:
On a related note, has anyone used the guest driver feature via the Lexus app? Does the shut off after the designated miles or time limit? Or does it just send out an alert? I’m thinking the latter as I’m sure there are liability concerns with a remote kill (although it would be very cool).
HINT:
HINT:
When the first ZR-1 Corvette came out in the early "90's it had a "Valet Key". When you were relinquishing control
to a Valet or other underqualified driver you simply turned this second key in its cylinder and removed it. Cut off the
second set of fuel injectors and limited a variety of other functions.
Ford has or had a chaperon feature called "My Key" that diminished various features including Media Volume.
GS3InPhx
05-10-04 01:59 AM
