what could it be?
Old 07-25-08, 11:51 AM
JayBmoney
JayBmoney's Avatar
Default what could it be?
let me start off saying this is the mos informative forum i have ever come across! second of all i am about to purchase a 93ls400 and it blows white smoke any ideas? i was thinking head gasket, and is it an easy fix or take it somewhere. also is it worth buying even tho iam getting a really good deal. sorry about all of the questions but i kno your the guys to talk to.
Old 07-25-08, 12:04 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
welcome to ClubLexus
please search, most questions you will need answered have already been answered in the past.
white smoke is likely from a leaking Air Control valve on the power steering pump, a cheap and easy fix.
Old 07-25-08, 04:33 PM
bigste
bigste's Avatar
I have the same 93 LS and beleive me they are bullet proof. I've never heard of the gasket going on these cars. The last reply is correct concerning the idle control valve but this would normally only show a lot of smoke at startup. It's an easy fix.
Old 07-25-08, 05:49 PM
jcrome04
jcrome04's Avatar
Is the smoke only on start-up or does it always smoke no matter what?
Head gaskets going out on the 1UZ are VERY VERY VERY rare. I'd say nearly unheard of.
The 1UZ and tranny are bullet-proof. Just keep up maintenance and replace your fluids with synthetics. I'd recommend Amsoil or Mobil1. Mobil1 is a lot more easily accessible.
Good luck on your purchase and welcome to the forums!
Don't forget to checkout www.lexusownersclub.com as well. Between these two site you'll learn more than you'll ever need to know!
Old 07-25-08, 05:56 PM
PureDrifter
BahHumBug
except the transmission, which must ONLY use Toyota T-IV transmission fluid.
Old 07-25-08, 07:40 PM
jcrome04
jcrome04's Avatar
Other than the tranny only needing Toyota ATF Type T-IV I've personally never really seen or heard of many problems.
Just maintain them right and they'll last you for years to come.
Old 07-25-08, 10:24 PM
melissac
melissac's Avatar
its the idle control valve. I had the same prob about 3 months ago took it off plugged it and smoke went away instantly. Its a pretty easy fix, I am a women and i fixed it myself.
Old 07-26-08, 09:16 PM
wutan
wutan's Avatar
Default nice
how much is the idle control valve? i have same problem. only happens when you first start up in the morning.
Old 07-26-08, 09:44 PM
dacecil
dacecil's Avatar
Don't replace it, repair it. The instructions are at the top of the LS400 in a sticky called "The Power Steering Bible." I repaired mine according to the write-up and it works perfect. Just like Melissa says, it's easy.
Old 07-27-08, 09:35 AM
trukn1
NELOC Mod
trukn1's Avatar
For those of you who choose to replace the Idle control valve on the power steering pump, it is a DEALER part only(as far as I have ever seen) and cost in the neighborhood of $125.
Old 07-27-08, 10:13 AM
JayBmoney
JayBmoney's Avatar
it smokes the entire time the car is running not just on start up?
Bakewalk
IS F (2008-2014)
07-11-18 05:53 PM
Cp2295
11-19-16 01:26 PM
Nesco93
Performance & Maintenance
05-24-12 10:04 PM
dougie23
05-01-12 09:47 PM
tallman316
22
04-09-08 03:34 PM
Quick Reply: what could it be?
