Help Highlander rim on Ls 400
Hi there every body I drive a 96 Ls400 and need to know if its possible that the 05 toyota highlander lemited rims will fit our Ls400....I know that for a fact the highlander bolt pattern is the same 5x114.5 and they are size 17, just need to know if they will clear the breaks and fit the lugs all the way in....thankyou very much heres the picture of the rim
[IMG][/IMG]
[IMG][/IMG]
Not going 4-wheeler but just wanted to see if it fit my ls400....some one told me that with some spacers and some new tuner lug nuts and grind down the caliper a little will fit right on......what do you guys think about that????let me know plz thankyou
BahHumBug
1-grinding down the caliper isn't really the smartest thing to do, you know, in case you ever have to STOP.
2-tuner lugs are the stupidest idea, why would you need those? lexus/toyota STOCK wheels ALL use flat/washer mount lugs. the other lugs would NOT work properly.
Go aftermarket with the wheels or get OEM ones from another Gen if you are just looking to change the appearance a little ( know that everyone is not rim money stocked). The Highlander rims (pictured above) don't look all that good to me on an LS. You can do soo much better with soo many other choices available.
TrAPsTaR87
24
05-28-11 03:05 AM
Rollaboy
12
11-27-10 05:37 AM
whalenpl
03-09-06 07:53 PM
