TUTORIAL: DIY Headlight Aim on UCF20 (95-97)
TUTORIAL: DIY Headlight Aim on UCF20 (95-97) (Works on other years)
Yes, promised to get this done months ago, HERE IT IS!!!
(lol)
1. remove top air intake and the filter+housing. also remove battery if u need to adjust the drivers side light as well. (i didnt need to so i didnt.)
2. Check the headlight aim on both sides using the green levels shown.
Drivers Side:
Passenger Side:
3.
Adjusting Vertically
turn this bolt while watching level to adjust vertically (up+down)
Driver Side:
Passenger Side:
4.
Adjusting Horizontally
to adjust horizontally (Left+Right) adjust the screw set in the white plastic ****.
Driver Side:
Passenger Side:
once again, here is a general Overview of the purpose of the adjustment bolts. (passenger side used as an example)
Props:None, its DIY yo!
(props idea jacked from LexLS)
any questions or comments pls lemme know.
(lol)
Drivers Side:
Passenger Side:
3.
Driver Side:
Passenger Side:
4.
Driver Side:
Passenger Side:
the 98-00 LS has the green level on the NON-HID cars i believe. but ur right in that the HID equipped cars had Autoleveling, so the only way to adjust them to go higher or lower is conning a service tech into doing it for you.
Good write-up. Some additional:
The little bolt on the fender side of the headlight assembly is the vertical adjustment for the fog light. The fog can only be adjusted for vertical.
The main headlight, the adjustment **** is dual action and pulling or pushing it adjusts it either vertically or horizontally when turning it. There is an unlock tab you have to disengage before making adjustemnts. The tab is missing from PureDrifters headlight as pictured. So be gentle, our cars are getting older so these little plastic parts and gears are easily broken. If you peg the adjustment screw, don't force it, as you will wear away the gear teeth.
The green vials...are general guides but they aren't super accurate. Find a good wall and adjust to the beam charactersitics you want. BUT, there is limited adjustment and depending how the bulb is, the pattern changes. Take a dark towel and cover the headlight you aren't adjusting. This allows you to see how the beam is from the particular headlight. AND remember, go easy when adjusting. The plastic is aging so being too forceful may be a $$$ lesson if you need a new assembly.
Oh...cover the main headlight beam with a towel if/when adjusting the fogs.
Hello, recently someone hit my passenger side fender, damaging the entire headlight assembly. I was wondering when the body shop installs a new one, will the headlight auto adjust? I have a '00 LS400 with factory HIDS, thanks.
