TUTORIAL: DIY Front Rotor Change on UCF20/21 (95-00) LS400
http://www.dba.com.au/dimensions
I read a few post a long time ago and a dimension was provided. It's just a little shorter than the supra.
ok.. i read over everything. Im having an ishue. the two screws for step 1, they are not coming out at all. they only turn about 1/4 turn then stop. both screws are starting to strip on the heads cus they are not moving.
another ishue is i got duralast rotors and they dont have the holes for thoes screws or for the 2 barrowed bolts. so im also wandering if thies duralast rotors will even work? idk how they would stay on other than the wheel holding it on.
BTW, these are the rear brakes I am talking about.
i use an impact driver to remove those bolts that hold the rotor to the hub. it prevents stripping as you pound it out using a hammer (in my case, mini sledge). i never use a regular screwdriver. spray some PB Blaster or WD40 to loosen the threads.
NOTE: this was on my honda but the principle remains. you can see the sledge in the background.
as for the duralast rotors you received, they sound like they are floating rotors which is a normal design. newer lexus and toyota vehicles run a floating rotor. it will not fall out as the caliper will hold it on, plus the wheel makes it square as you tighten. this is normal...for the front.
but...i would return your rotors and get the proper rotor that has the provision for the bolts. the rear does have a drum brake in it, and i don't think a floating rotor is appropriate for this. this is what i would do!
Did this on my rears today fully expecting a fight with the rotors. Once I removed the screws, they came right out!
I used a drill with a screw bit to get the screws out. It's impossible to get them out by hand without stripping them.
I couldnt find a DIY or Tutorial on replacing rear brake pads. I have a question about doing it because all I need to do with my rear pads is replacing the fitting kit. I was wondering how do i go about doing this, and what tools would i need to do so? This is my first time doing it since I just got the money to purchase all the basic tools i need. Any help would be helpful.
UPDATE: so i decided to take a look at the LexLS website and found the DIY for the rear brake job. IIRC only the front caliper design was changed on the UCF20 compared to the UCF10. Can i just follow those procedures for the rear brake pad job? so all i would need is to get a brake piston compression tool and no need for a brake bleeding kit?
Last edited by MValentine; 07-03-13 at 12:17 AM. Reason: found additional information
Any chance someone can provide the rotor mounting bolt specs? Just need the size/length seeing as mine are way too stripped already and will need to be drilled out...
Thx
Thx
