LS400 Lights mods
Old 12-07-08, 02:41 PM
qewani1
qewani1's Avatar
Default LS400 Lights mods
Guys check this out ....
http://celsiorup.com/cgi/lime/lime.cgi?down=http://celsiorup.com/move/WinkerPosition.wmv&name=ƒEƒCƒ“ƒJ[ƒ|ƒWƒVƒ‡ƒ“ŒŸƒ€[ƒr[(“‰)
Mod of corner light to act like normal + signal light all at once.
four fog lights instead of having 2 only
Have any one tried doing/did any of this?
if so...then
please share your informations...how to do that.
Old 12-07-08, 03:21 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the jdm and possibly euro spec LS' have running lights in the corners of the fogs, in the US you can even see the space on the back of the secondary pieces where you WOULD drill a hole for a light. it's something that could possibly be done at home.
the rest of it is pretty much just wiring.
Old 12-07-08, 06:13 PM
Kansas
Kansas's Avatar
The small unused light units next to the fog lights on the U.S. spec 98-00 LS400 has a stamp on the back of the housing that indicates that the maximum bulb size is 5 watts.
Member "98 LS" posted details and photos on 12/06/2003 on how to drill a 3/4 inch hole in the back of the housing using a Forstner drill bit from Home Depot and then use a Ford 84725 bayonet socket and a type 90 bulb wiring each side to the side marker light on the bumper. He bought everything except the drill bit at Pep Boys. I happened to print and file his instructions back in 2003 but I never did the mod.
Older threads on this forum prior to 2004 disappeared a long time ago -- I think there was a database crash or a redesign that lost the old threads.
I've thought about using the sidelights next to the fog lights as additional turn signals. One problem is that the small light modules don't have much depth -- my notes indicate that there is just less than 25 mm between the lens and the back of the light module -- which doesn't allow much space for a bulb big enough to be useful as a turn signal. Even though the housing is marked for 5 watts, I suspect that a much higher wattage bulb could be used for flashing turn signal without melting the housing.
The depth of the sidelights next to the fog lights in the above photo are much deeper than those in U.S. spec 98-00 LS400s -- it looks like those allow for some pretty large light bulbs.
Old 12-08-08, 05:56 AM
black_LS
black_LS's Avatar
That site (celsiorup.com) is gold! Lots and lots of DIYs on there with plenty of high res pics.
Good find.
UCF10: translated link
UCF20: translated link
Old 12-08-08, 08:32 AM
qewani1
qewani1's Avatar
Black thanks for the post ... great translate links...
PD
am going to buy some new corner fog lights as the above prev. pic.
PD i have a question for you if you don't mind? :P
can i take power from my existing fog light for lighting my new corner fog light. if course the corner fog light bulb will be same as existing fog light bulb.
so i will do some thing like this...
Old 12-08-08, 08:52 AM
Kansas
Kansas's Avatar
PD
qewani1, do you have a source for the Japanese market 98-00 Celsior corner lamps and sockets?
From this other cool site that was recently posted, it looks like the Japanese market cornering lamps use a bulb similar to the front and rear turn signals: http://www.*******.com/parts/p_J_200...EANK_8109.html
Edit: Don't know why but the second part of the URL "t o y o d i y" gets replaced by asterisks when I post the URL.
Old 12-08-08, 10:29 AM
qewani1
qewani1's Avatar
Kansas , i dont buy parts from the webs since cost will be high.
My source for parts is scrap (junk yard) or fake parts from the market.
I beleive japanese cars parts are rare in US right?
Old 12-08-08, 11:03 AM
Kansas
Kansas's Avatar
qewani1, thanks for the reply.
Cars made for the Japanese home market are very rare in the U.S. -- there seem to be more in Canada -- may be due to Canadian regulations that make importation of older nonconforming cars easier.
Do you have a source - either scrap or "fake" - for Japanese market car parts like the 98-00 Celsior corner light? Your location is "asdas". Where is that?
Old 12-08-08, 11:55 AM
PureDrifter
BahHumBug
PD
it should work as long as your bulb is made to run off of 12v. the only thing to be wary is that you don't draw more than ~15amp off the WHOLE circuit (both fogs and both corner bulbs that you added) since any more will blow the fog light fuse.
oh, and no crimp connectors here please, solder+heatshrink.
Old 12-08-08, 02:08 PM
qewani1
qewani1's Avatar
Kansas,
my location is Asia --> Middle East --> United Arab Emirates.
All kind of cars (American, Italian, German, Japanese...etc) are available in my country especially the Japanese ones, including their parts.
Old 12-08-08, 03:54 PM
qewani1
qewani1's Avatar
This is why i love this car.
Take your LS to the next level
Great car!
Old 12-08-08, 06:45 PM
TJW98LS
TJW98LS's Avatar
Kansas,
If that's the case, could you possibly find a junked 98-00 LS400 and buy the side fog housings and ballasts for me? I'd be willing to give you extra for what you pay if you could do that for me.
Old 12-09-08, 06:15 AM
qewani1
qewani1's Avatar
TJW98LS sorry i can't.
Old 12-09-08, 02:55 PM
TJW98LS
TJW98LS's Avatar
Awww but why? haha Any suggestion on how to find a parts place that might have one sitting over there?
Old 12-09-08, 10:28 PM
RA40
Super Moderator
RA40's Avatar
Can Carson Toyota order the parts?
Quick Reply: LS400 Lights mods
