Build Threads Details on Club Lexus LS400 owner vehicles
View Poll Results: Will cleaning the shift solenoids fix code 63?
Yes
33.33%
No
0%
Ammco just joking
0%
I dont know
66.67%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
My new 91 ASE tech/PICS build trans code 63 68
Old 01-14-09 | 07:47 PM
91 LS400's Avatar
91 LS400
Default My new 91 ASE tech/PICS build trans code 63 68
Just wanted to say Hi to everyone first time poster, but have be reading for about three months now. Love this place! Will test and clean solenoids on my day off tomorrow. The O/D light has flash at me three different times now but always after driving about 10 mile first. Cleaning the car if found a pan gasket in the trunk by the spear tire. This car is a lot quieter the my 91 civic.
Attached Thumbnails My new 91 ASE tech/PICS build trans code 63 68-img_0182.jpg
Old 01-14-09 | 09:18 PM
Seize's Avatar
Seize
Loves Snickerdoodles!
Welcome to Club Lexus
Old 01-21-09 | 06:17 PM
91 LS400's Avatar
91 LS400
FK it's back
made it almost a week with out a prob.
will clean them tomorrow!
It was like 10F last week 58f tomorrow!
Old 01-22-09 | 10:17 PM
hobojoe's Avatar
hobojoe
FYI fromt he pic your front pass tire looks a Bit Low!
Old 01-23-09 | 10:10 AM
MEANDAFAKA's Avatar
MEANDAFAKA
welcome and GL on the problem
Old 01-31-09 | 10:17 PM
91 LS400's Avatar
91 LS400
Well it’s been like 400 mile and now light
The filter is just a screen so I just clean it with brake clean and the bottom of the trans/valve body with both of the shifter solenoids in parts cleaner for ½ hr put it back to getter with gasket 15lbs pan was clean inside and on with silicone please don’t use silicone 3 ½ qts. Of Toyota ATF type 4 with filter and solenoids off. Both solenoids are held with one 10 mm. #1 shift solenoid was new and #2 was OE test @ around 5.3 ohms. Put them in opposite places as a test, they have the same part #
http://www.importperformancetrans.com/toyotaauto.shtml
http://www.lextreme.com/forums/showthread.php?t=3868
https://www.wittrans.com/c-1050-Volvo.aspx
http://www.transmissionpartsusa.com/...-00094920c.htm
http://www.transtec.com/rebuilder_news/1st_q00r-n.pdf
http://www.supraforums.com/forum/sho...d.php?t=267655
not my pic I left the camera in the car.. it look like his # 2 is new
Attached Thumbnails My new 91 ASE tech/PICS build trans code 63 68-dsc06478.jpg
Old 02-01-09 | 07:50 AM
MEANDAFAKA's Avatar
MEANDAFAKA
so any luck?
Old 02-08-09 | 10:17 AM
91 LS400's Avatar
91 LS400
No! I need 1 new shift solenoid 85420-50020 because it move to 1st and 3rd mostly hot remember I switched them around. Just manually shift it 124. Have a friend at Ammco checking on part price and I need to call this place by my house Transtar
http://www.transtar1.com/location.asp?ID=35A341E
Applications: Aisin-Warner A341E transmission
1990-2000 Toyota Chaser/Mark II/Cresta 2.5 GT/Tourer V (1JZ-GTE)
1991-1997 Toyota Soarer 4.0L V8
1993-1995 Lexus GS300 3.0L
1990-1994 Lexus LS400 4.0L V8
1992-1998 Volvo 2.9L I6 (AW30-40LE)
$155 is to much 4 a magnet and some wire! stay tuned a24auto.com
Hook me up like a tow truck!
http://en.wikipedia.org/wiki/Toyota_...smission#A341E
Old 05-15-09 | 09:30 PM
3UZFTE's Avatar
3UZFTE
Any updates with this thread? I currently have a tranny code #63, just curious as to what you came up with... I have read people soaking it in PB blaster and others in WD40. Any preference to one or the other?
Old 05-18-09 | 06:37 PM
91 LS400's Avatar
91 LS400
Default I love all LS
No, I still need to buy a shift solenoid or try a longer cleaning. I would pull them out and soak them in some kind of solvent any thing to brake down the varnish and gum. I wish I would have socked mine a lot longer the 30 mins. Mark them so you can switch them around! It will either work grate or your have to get a new solenoid and just manually shift it 1-2-D when it acts up.
Anybody if you live in St. Louis I work at a shop or on the side Damon 314-277-0745
62 - Open or short circuit in no. 1 solenoid valve "This is the code I get now"
63 - Open or short circuit in no. 2 solenoid valve "code before the clean and swap"
67 - OD direct clutch speed sensor signal malfunction "old code I think it was from the missing second gear and a little slip going in to third = 1 to 3 = slip
I have yet to see that code after the swap. I work on everybody else's car and don't have time for mine, but should have my own garage in 15 days! Lease is up on my apartment
Old 05-19-09 | 09:31 AM
3UZFTE's Avatar
3UZFTE
Well it's good to know your still here. Well, after I read this, and the other wonderful sites you posted, I went and tried it. I also did the shimming of the 1-2, and 2-3 shift accumulators. I still haven't really had a chance to drive it around other than around the block. The car drove well, but the fluid is still relatively cool, so I will have to take it on a cruise to really find out. I soaked mine in PB Blaster for about 1.5 to 2 hours. Keep us updated if you find anything out, or find a good price on a solenoid.
Old 04-24-10 | 06:12 AM
91 LS400's Avatar
91 LS400
I bought two new shift Solenoids for 115 from Whatever It Takes Transmission!!!!! So nice!
Now I love her again and am going to make her beautiful.
rtc1978
02-22-24 06:12 PM
ilgdrummer
GS - 1st Gen (1993-1997)
10-11-12 08:29 PM
nich300
12
06-19-12 11:53 AM
916ls400
02-18-10 12:43 PM
nyjdmevo
Performance & Maintenance
17
06-19-09 05:26 AM
Quick Reply: My new 91 ASE tech/PICS build trans code 63 68
