Vsc And Check Engine Light 1998 Ls 400
How do you reset the ECM on a 1998 lexus LS400?
I got this codes
P1349
P1656
I replace the vvt sensor 6 times
Could you please, help to solve this problem
I got this codes
P1349
P1656
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
hi when you said clean the chamber, you ment the housing that the valve goes in. How do you clean it? What do you clean it with. My ls is throwing the code for vvti malfunction bank 1 giving me 4 possible reason , but my car runs normal. I supposed all lexus with vvti goes through this.
I went ahead and cleaned both sides on mine, the pass side takes longer to get to it, but it solved my light problem....
wierd thing mines was doing exactly what your was doing,but it ran fine. Then I used the cruise control and it's gone referring to the check engine vsc light try that.
I just had this error occur on my '98 LS400. No engine misses, and no other codes, just multiple 1349s. Like Billy says, it was the oil control valve. My mechanic replaced it at a total cost of about $250 (parts and labor) and now all is well again.
Just wanted to reinforce the importance of the OCV to this code.
sandipvyas
11-20-17 06:08 AM
rico92562
11-24-10 06:54 PM
billydpowe
05-14-10 08:08 PM
