UFC20 rear strut rod bushings
i do have 2000 Ls and i know that for front strut rod bushings i can get oem from sewell
how about rear?
Adus 505? (as much as i could find they should fit all Ls years from 90-00)
any other option for rear?
where to order adus? armstrong?
how about rear?
1998 rear suspension bush search.
I have the same problem with my 1998 LS on both sides. The car has 300K miles on it. With the rear wheels off the ground I have 3mm of play pulling the bottom of the tire in and out by hand. The bush is one of two that
Lexus won't supply. Lexus only offer the rear axle carriers complete at $350 each.
Does anyone know where we can find replacement bushes?
There must be a cheaper way. Today I have looked into the "Lexus" route to replace these bushes. New axle carriers plus wheel bearings, inner and outer seals, dust covers and maybe ABS sensors etc. That comes to at least $1100 and maybe $1500 if I need the ABS sensors before the 6-8 hours labour. All this for two failed rubber bushes! There must be another option. Help!
do you need all this parts or just bushings?
so far i know that outer bushings can be replaced with adus 505 ($60 on ebay for 2) and inner are probably also adus 505 so another $60 plus labor
1998 rear suspension axle carrier bushes.
Does anyone know what the dimensions of the Adus bushes are? Length, diameter and bore?
