Elimiate Speed Governer on '05 LS430?
CL Folding Team Starter
Make sure you get appropriate tires.
I do not like to take the LS430 any higher than 120, the suspension gets a little hairy when the surfaces aren't smooth like some of the more expensive tracks. Even in sport mode.
I still think the S-Class and 7er are much better at supercruising speeds, but it's very rare that you can do that in America
Jdm Ecu
Has anyone here removed the limit? There's a guy with a youtube video who takes it up to 161mph (260kph), http://youtube.com/watch?v=47_qFLlTTe0
Thanks in advance.
Thanks in advance.
I've found the LS430 very stable, although I have not taken it above 120. I can't imagine it being less stable than my '97 LS400 at the same speeds, and I've found that stable when taken up to shutoff.
Just curious - but has anyone verified the speed limitations of the other drivetrain parts?
I know tires have a speed rating - but I'm talking about transmission, torque converter, drive shaft, etc...
I know I know - how can I make this comparison.. but bear with me: A few cars back, I owned a '96 T-bird V8. On the T-bird message boards people wanted to get rid of the governor on those also. Sadly, it was set to a pathetic 105mph! It turns out the torque converter & drive shaft couldn't withstand the higher RPMs or something. People would upgrade them with the Lincoln Mark VIII TC & driveshafts.
Lexus tends to over-engineer their vehicles (especially the LS) - but all I'm getting at is that the speed limitation might be there for a reason other than to keep you from going fast.
Anyone know how to remove 131mph governer?
...Lexus tends to over-engineer their vehicles (especially the LS) - but all I'm getting at is that the speed limitation might be there for a reason other than to keep you from going fast.
Ahh - I did not realize that. Have at it and let us know what she'll do!
I would thinks its would be pretty rare in most roads here in the US to get any extended speed that high. Maybe a burst here and there. Realistically, to build up speed that fast and to slow down without extensive braking, it would be a good 3 to 4 miles of "nice" clear stretch. I've done it in other cars before up to 140mph but it does get very hairy as you are risking your life and others on the road. Please be safe.
1. One of them is the SLD or the Speed Limit Defencer made by HKS. I'm not sure if they make one for 3UZ engines. http://www.hksusa.com/products/?id=781
2. This is the one I have, APEXi RSM (Rev Speed Meter), not on my LS but on my Nissan Cefiro in Thailand (in my signature) that had a 2JZ-GTE (Supra engine) swap. http://www.advancedjdmparts.com/prod...roductid=18218
Standard features include: Engine RPM, Vehicle Speed, Travel Distance, and Battery Voltage (All which can be displayed in real time graph mode, numerical mode, or analogue mode; 1-4 channels at a time.), Peak Hold, Replay (With 60 second playback.), Speed Limiter Cut, 0-100m, 200m, 400m times with trap speed, 0-100km/h, 200km/h, 300km/h times, 100km/h, 200km/h, 300km/h E0 times, user defined Mid Range Acceleration, Stop Watch functions, Best Time Memory, RPM Warning, Speed Warning, RPM and Speed Outputs (For external devices requiring an RPM or speed signal.), Tire Size Correction (For acceleration and timing accuracy.), and Vehicle weight input.
Think it would work on a 3UZ?
Sport suspension models
It's somewhat stable.
