DIY: Oil change Lexus LS430 2003
Old 03-02-09, 07:15 AM
kevin1533
kevin1533's Avatar
Default DIY: Oil change Lexus LS430 2003
I searched all over for pics on LS430 oil change before I did it on my dad's car. So I decided to take some pics and make a DIY article on ehow.
DYI: Oil change Lexus LS430
Old 03-02-09, 08:19 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
thanks for sharing, i have added it to our FAQ on the top of the forum.
Old 03-03-09, 05:01 AM
AlexusAnja
AlexusAnja's Avatar
Nice writeup Kevin. Maybe 2003 is different, but on my 2004, there is a "flap" you could call it, where you loosen two bolts and the "door panel" under the filter and plug area folds towards the front and locks open. Did you have to remove the whole front panel to get to your filter?
Also, once you remove with a wrench, you should then install hand tight so that when it comes time to remove later, you can remove by hand too, without the wrench. I've found that wrenches cause people to overtighten and then warp the seal causing leaks. I've never had a leak in over 400K of total miles changing my own oil.
Old 03-03-09, 05:45 AM
I6turbo
I6turbo's Avatar
My '03 has a flap too.
Re: tightening, if you tighten 3/4 of a turn after the gasket makes contact (common recommendation, and you can do it by hand), on many engines it will still be too tight to remove by hand (when the time comes to change the oil again) unless the oil filter is located in a place where you can really get a good grip on it.
Old 03-03-09, 10:29 AM
AlexusAnja
AlexusAnja's Avatar
Default RX engine only
I don't know how many "quarters" of a turn to do. All I know is that from my little Japanese 4 cyclinder where filter mounts on the side of the block, to 6-cylinders where the filter rests on the bottom, the only vehicle I have ever put a wrench to is my RX and that's only because the filter is down in the middle of nowhere where you can't get a good grip.
The LS is located so well, that any girly-man (no offense to girly men) with pencil arms can tighten and loosen it later. Wrenched filters, like pneumatically tightened lug nuts, are mechanics ways of overtightening so the average Joe with the wrong tools can't get those parts off.
Old 03-03-09, 07:57 PM
SH212
Dances with goats
SH212's Avatar
ahh beat me to it i was going to do a DIY with pics also
Old 02-03-11, 03:22 PM
Tom58
Tom58's Avatar
Does Lexus require Synthetic oil or will regular oil do fine? The maintenance manual states that a oil change is recommended every 5000 miles, so I'm assuming regular oil?
Old 02-03-11, 04:48 PM
PoBob
PoBob's Avatar
I believe that regular will do fine but breaks down more rapidly and therefore requires more frequent changing. The guy I bought my '06 LS from switched to synthetic oil with his first oil change. He drained the oil, changed the filter, filled the crankcase, ran it for a few miles, enough to thoroughly heat the oil, drained it again, changed the filter again and refilled with fresh synthetic oil!
Old 02-03-11, 04:52 PM
randal
randal's Avatar
Yes, "regular" dino oil is fine, Tom. Synthetic is nice (and expensive) and what I use, but is by no means required.
The only other thing I can add to this DIY oil change is that I pre-fill the new oil filter with oil before screwing it back onto the block. This soaks the filter material with oil and allows the system oil pressure to be reached more quickly when initially restarted. Probably ****, I know, but every millisecond w/o oil pressure is important to me.
Old 02-03-11, 05:59 PM
khanhdom
khanhdom's Avatar
yea synthetic isn't necessary, but doesn't hurt either
Old 02-03-11, 08:03 PM
AlexusAnja
AlexusAnja's Avatar
Synthetic is insurance for a worthy investment...
Old 02-03-11, 10:10 PM
MrXerox
MrXerox's Avatar
Guess I cant follow that logic...
Old 02-04-11, 12:07 AM
warminwisc
warminwisc's Avatar
Looks like the biggest PITA is what o do with the used oil.
Old 02-04-11, 06:41 AM
WB03LS430
WB03LS430's Avatar
I noticed in your write up you used 5w-40, any particular reason for changing viscosity?
Old 02-04-11, 02:16 PM
PoBob
PoBob's Avatar
I believe his logic was to ensure that the synthetic oil wasn't in the least bit contaminated. I believe he was quite **** and had deep pockets!
As far as the used oil goes, he said he saved it to use in his lawn and garden equipment.
Quick Reply: DIY: Oil change Lexus LS430 2003
