Recommended tires (20X8.5 and 20X10)
I'm thinking of buying a set of staggered 20's. I wanted to see if anyone was running a similar set-up.
20X8.5 And 20X10
What tire sizes would you guys recommend for an LS430 on a stock suspension. Also, what about on a lowered LS430 with Tanabe NF210s.
Any recommendations on tires?
Thanks for the help, and sorry if this has been covered before.
20X8.5 And 20X10
Hey TJW, Your tire selection is going to really depend on your wheel offset. For example on my 99 LS I have Vossen VVS 078 in 20"/9" +38 front and 20"/10.5" +45 rear and my tires are 245/35/20 front and 275/30/20 rear. Your car can handle slightly more aggressive offsets front and back to achieve the same fitment as i have.
Find out what the offsets are of the wheels you would like to get and post those up and one of the more experienced wheel gurus can help you out.
Michelin Pilot Sport A/S Plus is my recommendation. I have them in 245/40 and 275/35 19's and they are awesome tires for the LS, IMO -- smooth, quiet, excellent steering feel, and look good.
I'm a picky sonofa***** when it comes to tires, particularly re: noise and ride quality on a car like the LS.
https://www.clublexus.com/forums/ls4...ock-ls430.html
would just BARELY (if at all) tuck inside the fender when dropped as low as your car, yet yours with +22 offset appears to have about as much clearance as mine. Or the flip side, if my wheels protruded another 7/8ths of an inch (i.e. if my wheels had +22 offset), they wouldn't fit anything like yours.
I6 look at the specs on Mikes tires. That tells the story of his clearance, not to mention he is lower than you = more negative camber. If you replace your tires with the same width as mike + rolled fender lips, you will be surprised at how much clearance you have. Besides if I'm not mistaken there are some LS430's running front wheels with similar specs to your rears.
