Low tire warning
Old 03-16-10, 07:07 PM
mrpitbull
mrpitbull's Avatar
Default Low tire warning
I need some help LS owners. My low tire warning light is on and it came on right after I changed the tires out on my LS. I have 20s on it but went to a 245/35/20 from a 225/35/20 (that was the size on the car when i bought it). I don't know why its on because the tires aren't low. Help!
Old 03-16-10, 07:23 PM
JimsGX
JimsGX's Avatar
Here you go... From the owners manual...
After replacing the tires or wheels, adjust all
4 tires to specified tire inflation pressure and initialize the
tire pressure warning system. To initialize the system,
turn the ignition switch to “ON” and push the tire pressure
warning system reset switch for longer than 3 seconds
with the vehicle stopped. The following message appears.
"Pressure Initial".
Old 03-16-10, 07:35 PM
mrpitbull
mrpitbull's Avatar
Thanks... I was stressing over something that simple.
Old 04-07-10, 02:18 PM
kg19989
kg19989's Avatar
"Pressure Initial".
Jim,
where is the rest switch for this?
Thanks,
Keith
Old 04-07-10, 02:24 PM
Nick T
Nick T's Avatar
kg19989,
It is under your right knee ( above your ankle ) where the lock/unlock beep volume adjustment is.
Old 04-07-10, 02:48 PM
kg19989
kg19989's Avatar
Thanks Nick!
Keith
Old 06-12-10, 10:11 AM
Reyes
Reyes's Avatar
Nick T is right, its not visible from drivers position. You have to kinda reach for it. But good info guys!
Old 04-24-11, 02:41 PM
jeepman123
jeepman123's Avatar
Omg thanks
Old 11-04-11, 05:00 PM
spike_um
spike_um's Avatar
Default thanks
Thanks for the info guys. I picked up a LS from carmax and the light pressure light went off on the drive home. I was about to go nuts. I just reset it per instructions and will go for another test drive tomorrow.
Old 12-07-11, 03:44 PM
ttran832
ttran832's Avatar
Holy Holidays! Man, I had the same problem (tire low) warning light light 5secs. ago. Didn't even knew there were more buttons/***** there. Thanks you for the info guys!
wlpncp
RX - 3rd Gen (2010-2015)
09-15-16 10:29 AM
jlilexus
CT 200h Model (2011-2017)
12
04-21-13 06:10 AM
MadHungari
06-23-10 08:09 AM
danefx
08-29-07 04:09 PM
bigzip
04-10-05 10:10 AM
Quick Reply: Low tire warning
