White LED for switch clusters.
Old 07-24-10, 04:08 AM
motohide
motohide's Avatar
Default White LED for switch clusters.
Here's what I did using a little soldiering using 1w 12V LED singles by modding the socket base and removing the filament bulb and replacing it with LED.
No more green and and in place, a nice cool white color switch in the night time.
You can also make them glow orange like an AUDI simply by removing the 'condom' green caps off these filament bulbs too, but I just took the extra step and glued some LED's in place.
Old 07-24-10, 06:07 AM
Jabberwock
Jabberwock's Avatar
Hey looks good, how about ability to control brightness - does it get as dim in a linear fashion and in alignment with light output same as other lights for night driving.
Old 07-24-10, 06:32 AM
sojah
sojah's Avatar
nice mod and nice question too ^ ^ ^ .
Old 07-24-10, 09:09 AM
xuserx04
xuserx04's Avatar
very nice mod indeed. More info and more pics please.
Old 07-24-10, 09:27 AM
GLIDESUL
GLIDESUL's Avatar
Nice how bout a before and after shot. Probably to late for that. So many cool things to set your car off on this forum I'm gettin overwhelmed.
Old 07-24-10, 03:32 PM
motohide
motohide's Avatar
The particular LED's used, I can dim the interior cluster lighting to about 80% of the adjustment dial and it will dim accordingly at the LED as well. At about 20% the LEDs will just stop glowing, but at this point the normal cluster lights also are so dim its barely legible. So all in all it is very acceptable.
Old 07-24-10, 05:47 PM
PRSUIT460
PRSUIT460's Avatar
Looks great! I'd like to do that.
Old 07-24-10, 07:46 PM
Jabberwock
Jabberwock's Avatar
Thanks for the update - lights look very crisp and as long as the new lights basically dim along with others it would certainly be workable - it looks like a fun mod to try.
Old 07-24-10, 08:20 PM
TJW98LS
TJW98LS's Avatar
Did you do the Navi buttons as well?
You seem to know where to buy those LED's
V-LED is terrible for sending faulty bulbs and bulbs that barely last. Didnt you say you bought yours off ebay?
Old 07-25-10, 01:34 AM
motohide
motohide's Avatar
I just used LED's from a panel clusters I had sitting around for another use. However I just found a website selling almost identical to what I did to mine here, basically using similar bulb socket and stuffing a 1W LED into it.
http://autolumination.com/74.htm
You probably want the one that says "30% brighter than regular Neo - Wedge LED Instrument Panel Bulbs Type A, B & C" and the proper fitment for the switches pictured above is the Type B 10mm in white.
I would not get the double LED bulbs as they seem to not clear the holes on the switches, as its very tight fit, both length and the diameter of the hole.
PS: I did not do the Lexus navigation buttons since I have an aftermarket AV/NAV system, but I am sure if you are willing to take on the task of disassembling the OEM head unit and nearby switches, the result would be nice as well.
Old 12-17-12, 01:48 PM
karmaz
karmaz's Avatar
Just wanted to see if anyone has done this mod?
I'd love to update the dash, as i'm not overly fond of the green, especially the clock on top of the Nav unit,
I wonder if the clock could be done in white aswell?
Old 12-18-12, 07:53 PM
DRAG2GS300
DRAG2GS300's Avatar
nice job..............
Old 12-18-12, 10:42 PM
joerogan
joerogan's Avatar
only if I had the time and skill.
Old 12-19-12, 04:57 AM
karmaz
karmaz's Avatar
I'm considering dropping mine into a electrical installers here, and getting every bit of green turned to white.
I wouldn't be comfortable doing any of the soldering myself, I know i'd mess it up.
Old 12-19-12, 09:24 AM
ultm8mind
ultm8mind's Avatar
nice subtle mod...I'm sure it looks way better side by side stock
Quick Reply: White LED for switch clusters.
