will these fit with no rubbing??
Old 07-29-10, 09:23 AM
sojah
sojah's Avatar
Default will these fit with no rubbing??
Front = 19x9.0 +31 with 245/35/19
Rear = 19x10.0 +43 with 275/30/19
for a friend who has an ls430... and is lowered on datasystems controller only.
Old 07-30-10, 12:21 PM
AznRacer
AznRacer's Avatar
it'll fit without any problem
Old 07-30-10, 12:49 PM
waijai
waijai's Avatar
Should fit just fine.
Old 07-30-10, 02:38 PM
sojah
sojah's Avatar
muchos arigatos
Old 07-30-10, 02:39 PM
G_ride
G_ride's Avatar
I dunno how some people ride super low with aftermarket wheels. I have
20x8.5 225/35/20 +22
20x10.5 255/35/20 +27
and they rub like crazy. I had to raise my car twice and the rear still rub here and there.
Old 07-30-10, 02:56 PM
sojah
sojah's Avatar
are you on stock suspension with the controller or what cuz that may be why if you answered yes to the previous question. take out that little black fender lip thing and it should help a little if you haven't already ^ ^ ^.
so is it the larger the offset number the more aggressive or the lower the number? i thought it was the lower the number so if you have a pretty aggressive offset this could be why as well
Old 07-30-10, 03:48 PM
Tdvlexo
Tdvlexo's Avatar
You probably need to shave or cut your quarters also.
Sojah, you're right, the lower the number, the more aggressive it gets.
Old 07-30-10, 03:59 PM
RomanTPA
RomanTPA's Avatar
you need to know if those wheels will clear big-brake-kit.
if not they will not fit on the front
otherwise, will be a good fit. might have slight rubbing when doing U-turn and wheels will be almost flush
Old 08-02-10, 06:35 AM
hungwin
hungwin's Avatar
Yeah, the front wheels are Hyper Disc in the front and confirmed to clear Supra TT and IS-F front calipers, so LS calipers are not an issue.
sojah - thanks for being a soldier with this!!!
HMD
10-28-20 02:34 PM
02msmg3
07-23-12 06:08 PM
36Chambers
08-02-11 11:47 AM
GHSER7
10-15-09 09:16 PM
Lilflip#2
12-17-07 10:45 AM
Quick Reply: will these fit with no rubbing??
