Steering TELESCOPE FAILING - 2004 LS430
Old 11-16-10, 08:14 AM
JLAWS
JLAWS's Avatar
I circled what need to be take on off to see and easily grease the two screw gear.
Old 11-16-10, 08:54 AM
maximussp
maximussp's Avatar
Nice JLAWS. I will look into this. I'm assuming the gears are exposed and easy to identify? Or do I need to remove a cover plate to access the gears. Thanks.
-KO
Old 11-16-10, 09:50 AM
JLAWS
JLAWS's Avatar
Yes hit the column switch to see what gears move after the cover is off.
Old 11-16-10, 02:39 PM
BMW7_LS430
BMW7_LS430's Avatar
Someone please recommend grease. Better yet, provide an online link.
Thanks everyone for detailed pictures and description!
Old 11-17-10, 12:05 PM
StanVanDam
StanVanDam's Avatar
The only grease mentioned in the Lexus steering system manual is "Molybdenum disulfide lithium base grease". This is also the same grease as mentioned in TSIB ST001-04 (attached).
Old 01-14-11, 07:10 AM
gdigio13
gdigio13's Avatar
Hey Guys,
I'm having a similar issue in my 2001 LS430. Mine gives a grumbling noise and the wheel shakes a little. It only does it intermittently when retracting. Maybe 1 out of 5 times. I think it just needs lube, however, I just left Lexus and they told me 1.) there is no way to disable the feature 2.) its probably not a lube issue and 3.) I would probably be looking at $450 for one motor, $400 for another and several hours labor. This is of course before they've looked at it. They didn't have time to get it in until later. My appointment is later today to have it gone thru. Our local Lexus dealers in this area are owned by Auto Nation. I think everything is very black and white to them and would rather replace everything than help you find a reasonable solution. It sounds like my issue might have different symptoms than the ones mentioned here but any info you have would be appreciated.
Thanks
Old 01-14-11, 07:40 AM
JLAWS
JLAWS's Avatar
I had simiar issues with my 1st and 2nd Ls430. Greasing the gears fixed the problem on both of them. When the gears are dry you'll start to hear noises and then the motor will fail after a while since it struugles to move.
I used heavy duty grease that's for ball joints and grease fitting etc. You can find the stuff in any automotive store. Get get a small can or small tube for a small grease gun. The stuff takes a loooong time to break down and you won't have to worry about it for many years. Read my previous posts to do it yourself or someone not afraid to attempt it. Well greased steering column gears will sound like "light blowing air" when it moves.
Old 01-14-11, 06:06 PM
MrXerox
MrXerox's Avatar
How did I not think of this analogy first?!
Old 01-27-11, 08:12 PM
430drvr
430drvr's Avatar
Just developed this problem on my '04 LS w/ 76K miles. No symptoms until light squeaking on the auto retract. Will try jlaws fix, if the motor isn't already dead.
Old 01-27-11, 11:00 PM
430drvr
430drvr's Avatar
Default Other lube points
When I looked at my steering column, it was clear that in addition to lubing the telescope jackscrew, you should lube the metal column housing, and try to lube the carrier bearing that's halfway between the motor and the end of the jackscrew as well. Both of these are potential friction points. In my case, the problem is the carrier bearing, and that's too tight for grease, and probably not pullable from the column assembly.
We're certain that you need the dealer to shut down the retract on exit feature?
Old 01-28-11, 06:09 AM
caddyowner
caddyowner's Avatar
Originally Posted by 430drvr
... We're certain that you need the dealer to shut down the retract on exit feature?
Alas, it's not a user selectable option.
Old 01-31-11, 05:31 AM
gdigio13
gdigio13's Avatar
I took the car to a local and former Lexus tech. He used a special grease he said Lexus developed just for that problem. Once applied the problem ceased immediately. Funny thing is, Lexus wanted me to change both motors at almost $900.00 just for the parts.
Old 06-18-11, 09:40 PM
ddm17
ddm17's Avatar
Okay, I just bought my '01 LS430 and the telescope function does work at all. There is no motor sound or function at all. I have no idea if the telescoping functionality was turned off, if that can be done, or if it needs grease, or if some motor has failed. The fuses are fine.
Has anyone else had this problem and is there a DIY repair?
-Dan
Old 06-19-11, 04:35 AM
caddyowner
caddyowner's Avatar
Do a search here as there are a number of threads about it. IIRC, one even has pics. If the automatic retract feature has been turned off, the steering column should still be moveable using the switch. If it doesn't budge, I'd try the disassembly and see if the gears move at all when the switch is engaged. It could need grease, a new switch, or (most costly) new motors.
Old 06-19-11, 06:23 AM
Jabberwock
Jabberwock's Avatar
To clarify - The feature that can be disabled in the "cbest" settings, (only by the dealer) is the automated retract and repositioning of the steering column when the car is started or shut down. Disabling this feature stops the automated positioning but still allows for all manual adjustments to the steering column. So if the column does not respond to manual adjustments it is because something is jammed or there is a motor problem, and not a cbest setting.
Quick Reply: Steering TELESCOPE FAILING - 2004 LS430
