Rear camber adjustment
Old 12-15-10 | 04:02 PM
waijai's Avatar
waijai
Default Rear camber adjustment
Who has aftermarket arms for rear camber/toe?
I know there are several different arms available in the aftermarket world, but i wasn't sure who has used what and in what combination. For ultimate adjustment, Nagisa has 3-4 different arms for the rear. Just wasn't sure which one was most beneficial.
Old 12-15-10 | 04:49 PM
sojah's Avatar
sojah
i have the rear lower control arms that have no adjustment they are just 5mm shorter than stock, they also make ones that are 5mm more than stock for 5mm added negative camber. they were like $130 or so for the set and i was charged like 75 for the install even though with a lift i could have easily installed them myself. then i got an alignment and was all done for like $300 which is prolly a lot cheaper than even purchasing the nagisa ones if i'm not mistaken...
Old 12-15-10 | 08:15 PM
User 82021's Avatar
User 82021
Originally Posted by sojah
i have the rear upper control arms that have no adjustment they are just 5mm shorter than stock, they also make ones that are 5mm more than stock for 5mm added negative camber. they were like $130 or so for the set and i was charged like 75 for the install even though with a lift i could have easily installed them myself. then i got an alignment and was all done for like $300 which is prolly a lot cheaper than even purchasing the nagisa ones if i'm not mistaken...
i think you are talking about lower arms for adjusting camber, the shorter the arm on the lower, the less negative camber you have. i have the same arms.
i saved my original ones to weld in an adjustable turnbuckle into them.
i also had some uniball upper FRONT balljoints made so i could make front control arms.
the top picture has the new balljoint next to a stock upper front control arm
Old 12-16-10 | 05:58 AM
sojah's Avatar
sojah
yeah you are right, my bad, i meant lower rear arm.
Old 12-16-10 | 08:11 AM
bluerex's Avatar
bluerex
Where did you get them them for 130 a set?/ i need the longer ones that add camber
Old 12-16-10 | 10:56 AM
sojah's Avatar
sojah
i'm looking for the link but it may be on my home computer.
Old 12-17-10 | 12:56 PM
User 82021's Avatar
User 82021
i paid 130 each for mine i believe....
Old 12-17-10 | 01:31 PM
Celsior21's Avatar
Celsior21
i'm looking for some too but they are 130 a piece?
HiloDB1's Avatar
HiloDB1
Wow thats awesome. Any chance of having more then one set made? If so Id be real interested.
Old 12-17-10 | 02:01 PM
Stu's Avatar
Stu
My car is stock and the rear camber is slightly out of spec ....
Seems like Lexus made some errors with the rear suspension ?
Old 12-17-10 | 04:48 PM
waijai's Avatar
waijai
What was the actual measurement? All cars should have some slight negative camber. I think mine was -1.8 on one side and -2.0 on another.
Old 12-17-10 | 05:32 PM
FIGS's Avatar
FIGS
The Maker
anybody want to post up pics. I may be able to adapt some parts I have made for other models.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 12-17-10 | 05:43 PM
HiloDB1's Avatar
HiloDB1
http://translate.google.com/translat...%26prmd%3Divns
These are the only pics I can find on the Nagisa arms from the site.
Old 12-17-10 | 06:59 PM
FIGS's Avatar
FIGS
The Maker
Well its hard to see what goes where. But none of their stuff looks that impressive for the price. I think I have all the base line components, just may need a new center linkage. I have tapered studs for the upper ball joint, the toe links and the tie rod ends. I will look through the techstream info available and other diagrams.
__________________
Old 12-17-10 | 07:18 PM
HiloDB1's Avatar
HiloDB1
If you can make something like I said before Id be very interested. Im definitely interested in parts with a good amount of adjustment for front/rear camber, front caster, and toe front/rear.
