My AC stinks fix
Old 06-13-12, 09:45 AM
JT2MA71
JT2MA71's Avatar
Received 1,574 Likes on 687 Posts
Default My AC stinks fix
I tried the deodorizer many times before and also replaced the cabin filter and made sure the drains are not plugged. This issue doesn't seem to want to go away. So, I went ahead and bought this kit that injects the foam treatment almost directly into the evaporator, I guess. We'll see how it works.
Remove the cover under the glove box compartment.
This exposes the the ducting between the blower and evaporator.
.25" drill bit with stopper.
Drill anywhere on the flat section, this was the best spot I can do with my drill setup.
Fitting that comes with the kit.
Fitting installed.
Can with the hose and fitting attached.
Followed the instructions which was,
Hook up the end of hose to the fitting. Start the car up, turn ac full blast while set on outside air, empty can contents. Shut car off, let sit about 10 min. and start again and turn AC on. Disconnect hose from fitting and install supplied cap on the fitting.
Re install cover.
Put on new cabin filter.
That's it. Enjoy clean smelling AC!
Old 06-13-12, 12:01 PM
wil1688
wil1688's Avatar
Wow great instruction, I been having the same problem for years. please let us hnow how it work out. BTW, which kit did you order and who did you get it from. thanks..
Old 06-13-12, 02:40 PM
ancdmd
ancdmd's Avatar
Toyota sells a similar kit, you inject the foam straight up through the drain hose from under the car.
Old 06-13-12, 03:40 PM
JT2MA71
JT2MA71's Avatar
I got the kit from the dealer since I was already there to get some filters. I am sure similar or the same kits are available from other shops. I chose this method after trying the other stuff that is sprayed on the intake ducts up under the hood, I used several cans of those. I also heard about the ones sprayed up into the drains. I thought this kit has the best chance of fixing the issue because it is closer to the evaporator and the flow of air will force the stuff even more into it.
Old 06-13-12, 06:45 PM
duvalex
duvalex's Avatar
I had a smokey wood burning smell in my car from a bond fire a couple friends and i had two weeks ago. I thought is would go away but didn't. I took it to the dealer and they did an ozone cleaning through the entire air system. They said it hooks up to the receiving vent that sucks internal air and releases a air chemical like a bleach type that kills all bacteria, mildew, or whatever in the vents and gets the car smelling good again. Cost me $42 and took like an hour long. Car smells great now and its the same process they do when people trade in cars with cigarette smell inside.
Old 06-14-12, 06:18 AM
Lynzoid
Lynzoid's Avatar
Drill my Lexus??? No, thanks.
Old 06-14-12, 08:07 AM
jayclapp
jayclapp's Avatar
My dealer service advisor told me that they used Ozium and it only required a few squirts into the outside vents. I purchased a can at Pep Boys for $5 and it really worked. If I get even a hint of a bad odor I use it sparingly. I also use it yearly after replacing the cabin filter.
Previously I had used Lysol brand spray, which didn't really work very well.
Old 06-14-12, 09:05 AM
imherenow
imherenow's Avatar
where would the location be on the 2000-2001 es300
Old 09-22-12, 07:39 PM
loughery
loughery's Avatar
time to get ready for hot air through hose filters...Thanks for the post!
Old 08-06-13, 09:41 AM
Joe Cat
Joe Cat's Avatar
Just curious, How is the Odor now- Almost a year later
Would you still recommend that fix!
Joe Cat
jmkiang
General Classifieds
09-27-10 07:12 PM
TXSTYLE
04-25-10 12:37 PM
MrYoshi
SC- 1st Gen (1992-2000)
30
06-20-09 12:25 AM
LexFather
06-29-05 03:07 PM
Quick Reply: My AC stinks fix
