Other than scheduled maintenance, what preventative maintenance do you perform?
Hello all, brand new to CL. I tried searching but only found info regarding scheduled maintenance.
Besides the scheduled maintenance does anyone do any preventative maintenance on their 430's? I recently purchased an 02 with 87k on her. Dealer serviced every 5k, and 90k service done prior to purchase. Trying to keep this one running like new for well over 200k. Any suggestions?
Follow scheduled maintenance.
Do drain and refill transmission (Avoid flush if it was never done before).
Check for under-body rust and based on condition do some POR-15 treatment.
Protect paint and keep interior in good condition by detailing the car regularly.
Drive gently
That's all I can think of.
Drive gently
Clean MAF Sensor
Clean Throttle Body Assembly
Replace Thermostat with Gasket - some dealers don't include this with the 90k service
Replace Power Steering Fluid
Replace Brake Fluid
Replace Drive Belt
Replace Air Filter/Cabin Air Filter/Front seat air filters
Drain and fill Rear Differential
Check Lower Control Arm Bushings to see if cracked - usually need to be replaced around this time.
Drain and Fill ATF - "super easy" for your '02
Check Hood Struts
Check trunk struts
Check to see if coolant was flushed out or completely drained vs. just replaced what was lost with 90k water pump service.
Check alignment
Check tires for wear etc. - makes a huge difference if they're not "good"
Check windshield for cracks etc.
Check Door /Weather Stripping
Replace Wipers
Make sure you have a wheel lock key if equipped.
Always good to have more than 1 key.
BTW, I recently purchased an 05 UL with 123k and did all these things + some.
Replace Brake Fluid
Replace Drive Belt
Check Hood Struts
Check trunk struts
Check alignment
Replace Wipers
Bmw why do you say avoid tranny flush if not done so already?
As for everything else, I believe it has been very well maintained. Interior and exterior are in immaculate condition besides a few paint chip near front grill (rocks getting kicked up likely). Tranny fluid is fresh (not sure if it was a flush or a drain/refill--whats the difference?) Everything seems in tip top shape. Impressive for being 12 years old. My 95 LS400 that I traded in was pretty beat up on the interior but engine ran smooth. Transmission was strong but needed a while to warm up (in cold weather would not even shift into drive from a cold start)
On my 02, and yours, just pull the transmission drain plug and get 3 quarts out.. just like an oil change(tranny pan located immediately behind the oil pan). Then refill through the tranny dip stick exactly what you took out. Use the Toyota type IV fluid.. about $6/quart. I'm doing that 4 times, once every 500 miles (first time done was 150K) then doing a single drain/fill of 3 quarts every 15K.
Flushing the tranny is like blasting liquid through it.. it's much safer to drain and refill. Lexus mechanic's have said that a tranny filter doesn't really get that dirty even at 200K, but someone else can clarify how true that is.. With your mileage, if you do regular drain/fills then your filter shouldn't get too used up.
I'd get into the routine of doing the drain/fill now and you should be good to go way past 200K miles. I"m hoping for 400K with some suspension work thrown in there.
Hey, go get that $50 grill upgrade on ebay that looks awesome... black chrome.. I have it and love it because it makes the car look much newer.
Unfortunately, terminology gets in the way of communication. There are three types if "refreshing" the ATF:
1. Drain & refill = drain fluid and replace with the same amount. This will refresh the fluid if repeated a few times.
2. Fluid exchange = uses a machine to suck out and simultaneously replace ALL the ATF. I believe that it uses the transmission cooler lines, but an not certain of that. Downside is that it costs maybe $200.
3. Power flush = just as it says. This is the NOT RECOMMENDED procedure.
Thanks for all the info. All services have been performed at the same Lexus dealership so my guess is that the transmission has not been "flushed" but rather drained and refilled. I have put some thought into the black chrome grill + emblems but my car is the blue onyx pearl (dark blue) so Im unsure how well black would look. Currently the stock grill and stock (gold) emblems are in good condition. I contacted dealer and everything that was recommended for the 90k service was completed except the water pump. Trans fluid is brand new, oil is brand new (will be doing 5k oci's w/ m1 + 90915-20004 filter), and all recommended filters have been changed, along with all parts inspected/cleaned.
Clean MAF Sensor
Replace Brake Fluid
Replace Drive Belt
Check Hood Struts
Check trunk struts
Check alignment
Replace Wipers
Replace Brake Fluid
Replace Drive Belt
Check Hood Struts
Check trunk struts
Check alignment
Replace Wipers
I believe the coolant was changed with 90k service. Im going to hold off on the water pump until it starts leaking or becomes problematic. 90k is a little low for a water pump to go out, I think closer to 120k is when it should be changed. I didnt pay for the 90k service so if im lucky my pump will make it to 180k at which time I can have the pump replaced with the second TB replacement and only pay labor once. Iv heard of many LS' s going over 200k on the original WP. My LS400 that I traded in had 165k on the clock with original pump and being a 95 was just shy of 20 years old.
I believe that the water pump should be changed out when the timing belt is replaced, since the parts cost is small compared with the labor cost (or your time, if you DIY). Or you could change it out every other TB since it is pretty reliable. Just be aware that it does occasionally happen that the water pump can seize and take out the TB, which will destroy our (interference) engines.
Also, there are other preventative measures that you could consider, like lubricating the steering wheel tilt & telescope gears.
The above list is very good; almost everything else is OK to be left until it breaks.
I don't know offhand, but I am pretty sure that there is a thread giving the procedure for lubing the tilt/telescope mechanism, and if I am not mistaken it even had pictures.
I have not had great success with the standard search, but the advanced search works quite well.
